Have a few things from my N/A setup that I want to sell:
Armor Coated Pacesetter header: $150 (just header, no hardware/downpipe section)
K&N Typhoon short ram intake (revised version): $150
1st gen DSM BOV: $15 (the flange is welded onto a section of 2.25" mild steel pipe. Let me know if you want that as well)
Forge internal wastegate: MAKE OFFER
"You can only feed them semen for so long before their legs fall  off."
L61
thats the one with the plastic screw in fitings ?
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
Plastic screw in fittings???  All the fittings on the intake are either slip on and the IAT sensor which pops in.  No threading...
you have the Early  intake. the new versions have plstic screw in fittings and bracket that bolts on now.
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
If you're talking about the support bracket then yes, it screws in.  This is the new version of the intake.  I thought you meant all the vacuum lines.
i ment those as well. i have the Newest version and the vac lines are now thread in pieces
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
Interesting....I guess they updated it again even after the broken bracket problem.  Are they just screw in fittings with slip on male ends for the hoses?
yep,  they didnt really fix the bracket , i had the mod the bracket so it fit proper
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
