Hi guys, I am looking for a cavalier, but once I get it I'm thinking about getting it 2 inch lower,
Could you guys recommend me a cheap / good lowering springs?
and also
http://meganracingwholesale.com/i-128732.aspx
it says front lowering 1.75" does that mean it's ganna be 1.75" off the ground? or it's going to drop 1.75" from the stock height?
0--------------------------------
Could you guys also recommend me a good (not loud) muffler ? that won't be too expensive for a 18 year old.
(I'm new to modding or adding stuff to the car)
Its 1.75 lower than stock height.  Look thru the classifieds on here and find u some eibachs.
Oh i see, but so you'd say megan racing isn't good? or.. and i don't want it too low, 2 in or 1.75 would be perfect.
Just make sure you get new struts made for lowering to go along with those springs. You should probably expect to spend 500-600 easy for a quality setup.
lafonjef wrote:Just make sure you get new struts made for lowering to go along with those springs. You should probably expect to spend 500-600 easy for a quality setup.
What would be like the cheapest set up..? because I'm a teen and low on budget...
cheapest I found that I have heard people of using sucessfully is the tokico HP blues and springs.   they can be found on ebay most of the time for around 600...
clicky
I got some stupid cheap Sportlines up on the classifieds... been trying to sell them for months.
Don't cheap out on suspension... you'll end up needing to change it up a year or so later.
________________________________________.
Still not low enough for a signature.
Wait i tried to find that full coilover setup on classfieds. couldnt find it and
Twenty4z could you give me a link to it?
