nice!! every1 should have an ecotec!! r they all 4 spd auto trannys??
yes all are 4 speeds.
and yes Zack, let do it man
hey Aaron will this still be available early summer?
yes it will.
for all pre 200o owners you will need alot of parts
yeah, i've looked into it some. Still cheaper than getting a new car though
Ok how MANY parts are we talking here?
I'd seriously swap if I knew what all I really needed.
Proud member of
JBOK (J-bodies of Kentucky)
well you will need the 2000+ fuel tank with pump, full body harness and electronics, might need the full fuel lines that run under the body, the ecotec with tranny, harness, ecu, rack n pinion, upper mount, ect
holy @!#$ that sucks
I need an 03 rail, injectors, spacers and regulator
Phlatcav wrote:well you will need the 2000+ fuel tank with pump, full body harness and electronics, might need the full fuel lines that run under the body, the ecotec with tranny, harness, ecu, rack n pinion, upper mount, ect
are you for real? you need to replace the actual gas tank? rack n pinion? why?
but i need a new engine for my car, its a 98 fire. how much for a full swap? i remember reading your post about your engine/tranny you just did and you said you paid $400. is that the same deal for these? or are you a retailer or whatever and making some green too?
-----I'm such a NEWB!-----
---caleb
GAs tank cuz they changed in the newer models and the rack because i give it free with themotors and it is better than extending your PS lines. I make ZERO profit off the motors, Im selling them to help someone out.
can you post how much? if not, would you email me a price? i guess id need a full swap.
---caleb
How much for just an engine? No wires, no computer or trany.
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
RandomGuy 171 wrote:Tony Wise(emokidpsy) wrote:if only i had money and time for a swap
FireStarter: All that stuff isn't 100% necessary per-say. But you will have to "modify" alot of the stuff you have now if you don't replace it. In most cases it's just easier to replace it all.
