Megasquirt-2 CPU (CAN equipped version)
Megaquirt V3.0 main board
Megasquirt relay board
RS-Autosport complete wiring harness kit
GM coolant temp sensor and pigtail harness
GM 4 cylinder DIS ignition module (2.3 Quad 4 module which is used to install this system on a LD9 or Ecotec)
Pictures:
Main unit (testing Stimulator not included) and MS2 CPU
Relay board
Wiring harness
CLT Sensor and pigtail (on the right) and free pigtail for the IAT sensor (on the left of the image)
All of the Megasquirt items were purchased in kit form via DIYAutoTune.com and assembled by me. I've fully tested the unit and it is working fine. The only option not currently installed on the board is the high current ignition driver. If you want, I can install that option (which is NOT needed for installation on a J-Body) before I ship it out to you. No big deal. Otherwise, I'll just include the extra parts with the package and you can do it yourself if you choose to. I should also say the system is completely brand new. Not a single part has been used on a car.
The only other thing you need to complete this system is an open air IAT sensor. This can be had from www.rs-autosport.com for a couple bucks. I do however have the wiring for the IAT sensor which I will include for free with the purchase.
I paid roughly $450 for all of this stuff. In assembled form like it is, the hardware alone costs $500 from DIYAutoTune.com for JUST the main system, cpu, and relay board.
The price is $400 and you pay shipping. I will NOT ship outside of the United States. Please contact me at thepute2@aol.com if you are interested. Thanks.
I will NEVER change my sig. HTML 4 EVA!!
Is it using the internal MAP sensor, or is it wired for a GM sensor? Or, can you wire it for a GM MAP sensor?
The unit has an internal 2.5 bar MAP sensor. You can't see it in the main board picture, but the nipple for it is just below the main connector that the Stimulator is hooked up to.
Alright, free shipping.
