Lambos in the Winter - Mid East Region Forum
Monday, January 19, 2009 8:26 AM
Hey Guys.
I've never posted in THIS region before, so I guess I'm new. I just moved from florida..
Anyway...does anyone have problems with their lambos in the winter? Mine wont stay up. I'm guessing its because of the cold. I just installed them about 2 months ago when I was living in FL.
Just thought I'd ask.
Is there any Columbus meets?
Re: Lambos in the Winter
Monday, January 19, 2009 12:07 PM
PM sent
Friday, February 06, 2009 11:38 AM
cruizefest coming in coloumbus sumer 09
Sunday, February 08, 2009 11:20 AM
i live in PA my hinges work great in the winter. check your shocks for leaks. and what are they rated at lbs wise?
Sunday, February 08, 2009 11:37 PM
Mine work on my Sedan, when I go to my storage unit to see my car they work. Anyway, they are not as fast and not as stiff.
The same set-up on a buddies Coupe, well once it gets to 40degrees or lower, he DOES NOT raise the doors, they will fall down. The shocks seems to not be as strong or even close in the cold weather.
If you had shocks that held your door up in the cold, once it got warmer out, you would more than likely have a had time getting them to close.
Monday, February 09, 2009 11:47 AM
It's because they are gas shocks. When it gets cold, gases get more dense, and exert less pressure. Same concept as working with a cold air intake, cooler air is denser air. If they are putting out less pressure, they won't hold the same ammount of weight.
Yes, noob, the search button is for you...
