FS : 1988 Fiero 2.5l 4Cyl Auto Coupe - Mid East Region Forum
Tuesday, August 25, 2009 12:37 PM
124,000 Miles
Non-Smoker
Options :
Rear Defrost
Aftermarket Sunroof
Has Lloyd embroidered Fiero Mats ($100 new)
Originally bought this car to do the 3800s/c swap. Ended up as a daily driver for the past few years and now need funds for another project.
The Good,
Has working CD player, all speakers working well for OEM.
Interior carpet is very clean, door panels in good shape. Headlights flip up and down, work great.
Car has been reliable daily driver, do oil changes every 3,000 since purchased. Third owner, previous owner did not have car long due to blowing head gasket.
Got 31mpg on Highway during several trips to Cleveland and back from Cincy.
Car appears to be garage kept for most of life by original owner. Has very little rust on undercarriage, easy to work on and dissassemble. Entire front suspension has been recently rebuilt, along with top of motor and new fuel bump. Cylinders look great with very little ring lip at 113,000 miles. Tranmission shifts well, car starts and runs strong for what it is. Ebraking system works great. Car has newer Duralast alternator Very fun to drive.
The Bad,
Needs new tires, front are almost completely gone.
Rotors need turned.
Has typical rust-through on inner fender under battery tray due to acid leak.
Needs some interior cosmetic work, needs new headliner, needs console box door, has typical Fiero delam. around stereo console. Drivers seat needs patched, passengers is excellent. Cat. Converter has a hole in it somewhere, one layer is rusted through. Water gets in in the rain when sittings and causes it to steam. Rest of exhaust seems solid.
Car needs new temperature sensor because Radiator fan will not kick on during Idle but does with AC on.
Paint is in decent shape but has checking and scratches one would expect for 20+ year old vehicle. No major body damage anywhere
Maintinance History
113,000 Miles
Installed Rebuilt Head, new push rods, new head gasket, new exhaust manifold gasket, new crank position sensor, new EGR Valve. Replaced Throttle Body Gaskets. Replaced fuel filter. New plugs, new air filter. Replaced thermostat and radiator cap. Replaced Primary 02 Sensor.
116,000 Miles Replaced Rack and Pinion with New/Rebuilt Rack. Replaced Front Tie Rods, Steering Rack Boots, Front Upper and Lower Ball Joints. Replaced one upper control arm shaft. Replaced all A-Arm bushings with Poly including Sway bar connect Bushings. Replaced upper dog-bone engine mount.
120,000 Miles Replaced AC Compressor w/ rebuilt due to bad bearing. Replaced belt tensioner w/ yard pull. Power bled all brake lines. Replaced both rear brake calipers with new due to failed E-Brake. Replaced pads on all 4 wheels.
123,000 Miles Replaced Fuel Pump, Fuel pump filter/pickup. Replaced fuel filter. Replaced front shock dampers.
Part's included but not installed.
* New Shift boot
* New Monroe Rear Dampers
* New Water Pump (existing working fine)
* Includes spare decklid for shaving spoiler holes (needs work)
* Includes Factory Sunroof clip.
I have truthfully described car to best of my knowledge and ability. Car is being sold AS-Is, with No Warranty.
Price is $1500 Firm to be paid in Cash.
Car is available to see upon appointment in Oxford Ohio. Please contact via PM. Thanks
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Re: FS : 1988 Fiero 2.5l 4Cyl Auto Coupe
Wednesday, August 26, 2009 10:38 AM
You may want to try www.fiero.nl.
Wednesday, August 26, 2009 2:14 PM
SON OF A BITCH!!!!!!!!
Damnit why do things I would be willing to buy have to come up after major purchases.
GLWS
If you dont sell Ill come take it off your hands free of charge
JGM T-SHIRTS!!!!
Wednesday, August 26, 2009 8:05 PM
bump for a clean fiero and a legit guy.
JBOK.org / J-Bodies of Kentucky
Thursday, August 27, 2009 1:29 PM
Thank's, wish it was clean, like 1988 clean. I have to say I wish I would have put my performance $$$ into this rather than the cav, but I bought it at the time I had the cav torn apart
Friday, August 28, 2009 7:41 AM
How close would you be willing to meet near Toledo? (I'm north of you)
Friday, August 28, 2009 10:00 AM
jrim wrote:How close would you be willing to meet near Toledo? (I'm north of you)
I'm afraid it wouldn't be safe to drive that distance with the front tires in the condition they are. Ill give you a call.
Tuesday, September 08, 2009 3:30 PM
Local buyer ended up backing out, car is still for sale. Car may get tires replaced soon. Rotors have also been turned now. Taking Offers
Friday, September 18, 2009 8:07 AM
Sold! Thanks everyone.
Friday, September 18, 2009 2:37 PM
QQry this was the only car my 2.2 OHV Cavy could pull on! rofl
-Saint Augustine
Friday, September 18, 2009 4:01 PM
glad you were able to sell it man good luck with your new dd and keep us updated
Saturday, September 19, 2009 4:28 PM
~trOll~ wrote:QQry this was the only car my 2.2 OHV Cavy could pull on! rofl
Hah were you at the time I was at the track and put down an 17 sec 1/4 with it? Well it was good and dependable though, got me around while the Cav was torn apart.
