I want to have a compression test done before i go ahead and boost my cavi. Anyone know of any good shops near philly area that do good work?
go to PSIProformance there in lansdale or hell even RT tunning
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
compression test is easily done yourself
How can you do it yourself? PM with some info?
JokerAKA Showoff03LS wrote:go to PSIProformance there in lansdale
I've been there. I cant vouch for their work, but they do have a sweet Civic hatch with a twinscroll turbo.
219whp - I <3 whine
usually you pull off all the spark plug wires, or coil packs if you have them
remove the fuel pump fuse
remove one of the spark plugs, screw in the compression tester then have a friend turn the ignition for a few seconds, should show on the guage, works best with two people, then do the same thing for the rest
There should not be more than a 25% variance between your results in each cylinder, way way back I did my cav eco it was 210-209-183-208, thats pretty good but indicates that #3 is wearing more than the others
Okay. I think i will just go out and buy a tester and do it myself.
