Ok,
So I finally got pics, but they're on the one website.
Follow this link:
SUNFIRE PICS!
If you can't view the pics use my login info.
Login: neomas77
Password: ssf2thff
Quick car info.....
Basic info: ported gm eaton supercharger w/ 2.5 pulley, HPT tune, Boost guage, AEM air/fuel guage, LSJ SS/SC 378cc injectors,
cooling mist deluxe alcohol injection kit , 2.25" mandrel catback dual exhaust,
pacesetter 4-1 ceramic header, custom bored out throttle body, NO2 bottle hook up installed
Built engine info:
gtz 2.3 HO valve springs, jbp high rev 10k lifters, clevite 77 bearings, wiseco pistons (9:1) .020" overbore
eagle h-beam rods, cometic head gasket, APR head studs and new gm main bolts
2.3 HO oil pump conversion, 2.4 modified oil pan, decked head/block, 3 angle valve job
custom port and polished head, secret cams
tranny cooler
Exterior/Suspension/Others:
Factory suspension, 22mm front sway bar,
5% window tint
16" factory rims
clean interior, trunk
Stuff available (in my poesssion/in closet):
Factory Silver Sunfire spoiler, TTR tranny mount, Vibrant rear strut bar, Poly trailing arm bushings
Low resistence ignition spring set, MdLd9 light weight pulley set, HO .212 lift exhaust cam, Denso Copper plugs
2.4L gasket kit set.
Basically I'm not using the car at all. I had plans to use the engine but oh well.
Cosmetically, the fenders can be fixed pretty easy.
The car does have 5% darkness tint, so be mindful of that.
Price +/-$4000
I'm very flexible with any pay structure, just be consistent.
Give me a call or shoot me an email whenever
Thanks,
-Mastin
443-846-6428
MasSnead2@aol.com
I was thinking about this, but the damage done to the fenders and doors turns me off. Sounds like most of the money is under the hood on this car.
Yeah, this would be perfect for a donor drivetrain swap, or put new fenders on it.
^^ yeah,
If noone takes it, I'll put a fender on the driver side, pop out the other, and keep it.
Then maybe in............never, I'll actually take it out on the road.
-M
Man I wish I had the money when you had it up before, all my car needs is a decent drivetrain. But money is really tight right now, and with the holidays that makes it even worse.
if I had the money, this would be in my driveway...... well, at least long enough to put new fenders on it, and swap out the engine and s/c........
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Yeah,
I think I'll end up ordering the fender's on Monday.
At least the driver side, I got a guy that should be able for fix the divit on the other side.
Won't know until the end of the day tomorrow since I have a 'potential' buyer.
-M
