Ahhh, the photos of a Hard Core 1st gen owner!! Bravin' those elements for the score!
  You Go Josh!!
  Nice score indeed, and when you have then installed and are using them you'll always be reminded of your efforts today!
  Maybe next trip the weather might be a bit kinder for you lad!
Ok, So I'm scrolling down and see the digital dash.  I think I better tell him to grab it. Don't need to, he's already got it.   Good score Josh!
Yeah that yard is actually in Illinois across from Gateway Int. Raceway.  The snow was worse than I thought it would be.  There were 6 inch drifts in areas that made pulling my wagon a real chore.
I'm hoping the cluster is still good.  I couldn't test it due to an engine fire but he only charged $15 for it so it seemed worth the risk.
Were they snowmobile at the Raceway today???
looks cool.  The sunbird coupe appears to be an 86 or 87 with the later style bumper cover on the rear and the flares.  The console is a nice score if you are thinking of going back.  Was it a stick?  If so, I could realy use the shift plate from that console - even if it is wet
Clean Z24 - looks mostly there - good score on that dash.
Paul it could have been later.  I'm not up to date on Pontiac J-body models.  It was an automatic car.  I would like to go back and raid that z some more.  That is the first one I have come across with a power seat.
Josh, is the bracket around the bottom of the power seats, you know where the switch connects still there? I could really USE that plastic bracket on the drivers door. There is a picture of what I need on the 2nd page of the Cimmaron parts thread. If it's available, I'd gladly pay you for it and your time to pick it, of course if you're not gonna use it.
Walt Lewis
Walter, that bracket was still attached and as far as I can tell it didn't appear damaged.
Hi Josh!
Try and get Walter this small attachment  to hold the the plastic bracket on while you are at it. Walter will need it to hold everything together. Try to save all the screws too, he'll probably need them as well.
Here are all the screw locations:
Just to give you a heads up, those power seats are a PIA if you can't get power to move them back and forward to clear the mounting nuts.
If the engine is burned up, I suggest you might be able to take a battery booster in with you, then you can cut the wiring under the seat and make a temporary connection long enough to move things around.
 Also if the plastic shroud is still attached around the base, it is sometimes difficult to get this out of the way without busting it up. The on on the door side is a tight fit to put it mildly. Hope this will help keep your aggravation to a minimum! Happy Hunting!!
Thanks for the advice Orlen.  I will try to make another trip up there this weekend.
In all honesty I wouldn't mind swiping the dash out of that car.  It was near mint but I have never removed one.  Anyone know how those come out?
Josh Maloney wrote:Yeah that yard is actually in Illinois across from Gateway Int. Raceway.  The snow was worse than I thought it would be.  There were 6 inch drifts in areas that made pulling my wagon a real chore.
the fact that you found those cars at speedway in any sort of usable condition is a miracle in itself most of speedway's cars are wrecked pretty bad
for my cavalier i go to taylors in st louis they know me so well there i barely pay for anything i pulled a sway bar, mounts, bushings, links, strut brace from a vert, speakers, and a guage cluster and the guy only charged me 20 dollars. but they have quite a few first gens there too
im a third gen guy sorry guys
Nice finds for sure.Wish I could give you some insight on dash removal.However the one I wanted was crushed before I went back.I know it can be timely with all the controls,and screws and possible rivets to drill out I think.I am a touch tired 548miles today.I plan on doing a junkpile run this wk.I know there is a 87 bird sedan unless they crushed(however) they hold cars longer due to lack of them coming in.I will take my cam when I go.And you might want to grab the air cleaner if cowl inducted.
Jeremy,
 Thats pretty good as my local yard that keeps older stuff is a ripoff.  They have an unspoken rule of $25 for a minimum and $125 for
 doors plus the glass if it is in it .    You just never know what they will charge until you go to the counter and it depends on who you ask.  And the older pre 90's stuff is about 350 yards from the shop, so just to up and ask before you remove it is chore.
But Hey it's the fun of the hunt!
Josh I do know there are 2 bolts on either side and a bracket near the middle plus the screws at the top for the dash. No personal experience, but I've heard it takes some patience.
John, I Love your temp power supply!! Always a treat to learn something new!
Josh since you are in that deep, and will be moving the seat around, if all the motors are sound and you don't mind pulling the power seat base and switches, I'd be happy to buy them and and pay for the shipping. Sounds like you get reasonable prices where you are at and I might be in need of a spare! :-)
Happy Hunting!!
I will check it out for you Orlen.  I have to save that panel for Walter anyway.
   I am in need of a few parts myself so I wouldn't mind trading.  I need a right side door glass run for a coup and I am also looking for console pocket without the storage slots.
Josh I checked the 85 today and the pocket was the  cassette style.. Bummer. I believe though they might have the console parts I need. I am still interested in the window sweep from you though. The ones on this car were beat. Ya think the door glass parts you need are the same in a convertable? You posted newgmparts.com I believe they still had a console pocket for like $50.00. pricey I know but if all else fails...
I will grab the other window sweep for you Mike.  The door glass run that I need can only be found on 2 door coup j-bodies.  If you find one I believe you can remove it without taking out the glass.  Just roll the window down and pull it straight up.
door glass run--do you mean that metal at the front side of the window that the window is jammed into?
I think I have one of those off a coupe I could send you; I'll have to look for it.
Wayne its the rubber seal inside the window track that the window seals against.
