Hi People,
have a 1987 sunbird gt, (2 door) and man, the bottom of the doors have developed severe rust, even in FL. Both outer "skin" and inner door "skin" have rust which has migrated upward, beyond the "crimp" zone. meaning the lower say, 1-2" of both skins have to be cut out.
I understand this is not an easy body job since there are contours which have to be re formed/shaped, as the inner skin is rotted beyond the crimp zone and I jhave no idea how to shape such a turn/corner. One corner though is in great shape- it's the front corner which is rotted.
tried to search a used set of doors on car-part.com, but not happy with search results. Fix or search for used door? Ever fix such rotted doors, people?
Thanks.
Can be done, but in my opinion just replace them.  You can find doors if you search long enough.  Any door from 83 to 94 should  fit.  I may be slightly off on the years and there might be some modifications needed on the 2nd gens as the seat belts were in built into the doors.
Thanks, 84. Good tip. My 2 doors dont have seat belt brackets/components on doors. But I will search. Hey, where would you search other than car-part.com?
Check out your local junkyards or if you have a pull a part yard where You remove the parts you want and pay for the part not the labor cost with it.Easy in words but,the hard work if you find some solid doors you save in the cost over having a part removed,shipping and then you still have the rest to finish.
I'd also check the floor pans too, just in case. With the rust you speak of, I have the feeling the car has either been in a flood (common in FL) or it was up north during at least one winter.
LKQ has you pull it yards all over Fl. And you can see pictures of the cars on their yards on their site. 1990 was the first year the seat belts were on the window frame of the doors. So, try to find any good doors up to 1989.
Good luck
butch nackley wrote:I'd also check the floor pans too, just in case. With the rust you speak of, I have the feeling the car has either been in a flood (common in FL) or it was up north during at least one winter.
Good luck
Thanks, Butch. Good to know . Yes, Ive been to LKQ in the past, and there are 2 yards nearby. Thing is, every time Ive been there, no sunbirds, but you never know. They do not carry an inventory list, last time I spoke with them. Pictures? Really? Too much! Where can I find these pics of the junk cars in their lot?
Also, car has been in FL since 1988, just after 1 year of being new. I AM the original owner. Never been in a flood. Floor pans are still solid.
Thanks!
Thanks again, Butch, tried it. Yup- no sunbirds anywhere. An endangered/extinct species.......
Oops, forget that idea- just realized they are BOTH 4 door cars. sheesh!
