2.0 Olds Firenza firing issue - First Generation Forum
Wednesday, October 18, 2023 11:38 AM
Hello fellas… i’m new here… i bought a 84 firenza fwd and it has some firing issues… when first got it it was stalling on cold startup. from what i can find online the block from left to right is 1234 and the firing order is 1342. so i set the block to tdc and # was in the lower right corner of the distributor so i put #1 wire on there and the rest clockwise in the firing order. but on startup it doesn’t seem to be firing correctly… back fires through the carb and won’t start… any help would be great thanks
Re: 2.0 Olds Firenza firing issue
Tuesday, November 14, 2023 5:51 AM
still fighting with this distributor… can’t find any info on which way the rotor cap is suppose to be pointing… on most engines the cap is supposed to point to the #1 cyclinder… i’ve tried that and nothing… yesterday i drove 5 hours to pick up a haynes manual and when i looked it said nothing about rotor cap placement…if anyone has an 84 2L FWD OHV engine in their car or knows where some info is on this please please HELP ME…. lol this car is so awesome and need to be on the road Thanks
Tuesday, November 14, 2023 10:14 AM
Are you sure it's at TDC on the compression stroke? It could be at TDC on the exhaust stroke.
That would give you the hiccups you see.
Tuesday, November 14, 2023 10:57 AM
i think so…#1 cylinder is at the top.and my three timing marks are at 0. can’t find any info on distributor and rotor cap placement..
Friday, November 24, 2023 7:57 PM
This is Ron.Im a 1st gen owner since 98 in the family since 91.With out writing a novel on my knowledge I'll dig into and or show pics of some stuff.The firing order is right.Making sure it's o TDC and compression is imperative. The back firing is a Key tell tale of it doing its not timed right.It may require speaking the distributor once running,and a old school timing light!I haven't been on here in Forever,so I'll have to see if my pic posting will work using my Google photos.I have a 1985 type 10 cavalier all Stock 2.0 ohv with a 4 speed manual,sunroof factory! Color is yellow gold and it's a coupe.Mileage 198k stays garaged year round.I will follow up.
