Oki changed my Cat today and the car ran good for a while than..... it started chugging again but not as bad it is only when i stop at a red light and @!#$ but if i (feather foot) the gass it is better not great. my nebor said it is proabily my TPS, but as usual i would like imput from you guys. o and i changed the o2 sensor.
is it possible your timing is off somehow, or you've bent a valve in the head snapping a timing belt recently? have you changed the plugs and wires recently?it sounds like your timing to me, or the plugs/wires, kuz if it gets better with acceleration, it could be increasing the current, but then the tps is probly somethign to check to, i'm just throwing out ideas for thigns to look over
"I live my life a quarter mile at a time..." "for those ten seconds or less I'm free"
yea should i change the plugs i just put some bosh platinum2 in the car could that be bad. and no the belt has never snaped and the timing seems ok. but if i need to how do i change the timing i dont have a DIS.
I NEED THIS FCKIN CAR TO RUN GOOD
i got it fixed it was a bad coilpack. my pal at his shop fixed it 4 $400
Tyler Gilheany wrote:i got it fixed it was a bad coilpack. my pal at his shop fixed it 4 $400
$400 to fix a coil pack?   I hope they kissed you first.   The ignition module and coils shouldn't cost more than $200 if even that.   They are easy to change by yourself.
http://cavalierman93.googlepages.com/
