any1 with an opinion? - Second Generation Forum
Tuesday, July 19, 2005 10:30 AM
i am from ontario and i am lookin for the best engine for my 89 z24, without making it more of a hassle than i need. so if anyone has any suggestions than please let me know before i do something i will regret.
Re: any1 with an opinion?
Tuesday, July 19, 2005 11:04 AM
3400 swap is what alot will recomend. i belave its a drop in motor...
i'd say do a 2.0 OHC turbo swap.
Tuesday, July 19, 2005 11:15 AM
no the 3400 is not a drop in you need at least one knew mount
i would recomend the 3.1 3400 hybrid build
that or go turbo
Tuesday, July 19, 2005 11:17 AM
than do a hybrid... since u have the 2.8 you can put 3.1 heads on it correct?
at least that'll free up some power.
Tuesday, July 19, 2005 11:46 AM
I miss my 2g wrote:than do a hybrid... since u have the 2.8 you can put 3.1 heads on it correct?
2.8 and 3.1 use the same heads.
The best swap going right now for a Z24 is the 3400 because all you need is the new front mount bracket and since yours is an 89 you'll need the 92-94 radiator hose and overflow tank. You can keep all of your stock wiring, computer and transmission.
If you were to do the 2.0 turbo swap you'd need to swap all of the sunbird wiring, computer, and transmission. and if you wanted working gauges you'd need to swap to a sunbird dash setup.
Tuesday, July 19, 2005 12:12 PM
or you can use the 3400 heads on the 2.8 block make a hybrid
Tuesday, July 19, 2005 12:40 PM
like sunValier said i recomend a 3400. my brother is a member of beretta xtreme and he did the 3400 swap to his car, if you have a 3100 right now it wont be to hard of a swap, but if you have a 3.1 you will have to change a lot of your stock setup. but if you put it in i recomend having a 5 speed cause his automatic is already slipping cause the auto cant handle that much power, we are doing a 5 speed in his and other beretta owners say that the 5 speed will make just as much of an improvement as the 3400 did
Tuesday, July 19, 2005 3:58 PM
well maybe if you got a uprgraded tranny, or a fresh newier tranny it'd hold fine...
not using a tranny thats probably seen over 100K miles, than put some extra torque to it and of course its gonna screw up.
