my friend has a 90 2.0 ohc sunbird and the check engine light is on...the car wont start once it warms up and i want to check the codes and see why the CEL is on ..where can i find a list of codes to use when i flash the codes
Just a note if the cel is on u can check the codes with the car cold,regardless.If it's a hard code that's set the cel it will be stored in the ecm.Just hook up the plug in deal or ground it with a paper clip and check the flashes.If it won't start once warm could b numerous things,temp sending unit,coil ,etc.Ok
thanks for the help guys ill be checking the codes tonight after im off work
