does anyone know where i can get the abs harness for the sensor on the passenger side. checked auto shops but no one has it and the dealer wants ninety dollars for the narness.fuel gauge moves around a alot i know its suppose to move when you make turns. but it moves alot and the when i stop it goes back.it seems like something in the tank  maybe loose.any suggestion.thanks in advance.
Could try the local junk yard.
Are you sure they looked up the right part? The "harness" itself is only like 3 feet of twisted pair with a weatherpack on each end. It plugs into the main body harness.
Is it repairable? You can pick up individual weatherpack connectors and fix them yourself, or if its a cut wire, just splice it back together.
is thier anyway you can get the part number and maybe i can go to the auto part store and see if they have it.
could it be that my fuel sending unit is bad. i tried to look for the price of one and couldnt find out how much it cost. and if it is the unit  does it affect the gas or the mileage that i get.
