Idle air control valve.
I need all the info I can get on it....
93 Cav, 3.1, 140,000 miles..
I'm replacing the IAC, fuel filter, PCV valve.....
I"m trying to get rid of a few things..
- SUV mpgs (again)
- Rough idle (worst in warm weather/once warmed up)
- Lack of pick up
A coming down from a higher speed will usually throw the check engine light on....will come off and on..
Replaced MAP sensor, EGR just cleaned-same problem...
Info Please!
Pull codes before throwing parts at it.
When I do get codes, most of time it is the IAC.  Though I've noticed it will throw codes of other stuff too....doesn't help much.
