94 auto wont start - Second Generation Forum
94 auto wont start
Friday, July 20, 2007 2:55 PM
Hi all. 94 auto, was working fine a week ago, now wont start.
Has spark, it cranks over, and backfires sometimes, but wont start now. Has a fully battery, and gas tank. Disconnected battery and connected it back up again. (had to do that before to reset the computer or something) It started up before after I did that but now its not. What should I be looking at?
a noob weak A$$ 3 speed 94 cavalier ...
Re: 94 auto wont start
Sunday, July 22, 2007 7:40 AM
What is it doing exactly when you try to start it?
Sunday, July 22, 2007 2:45 PM
sounds like you have dirty or faulty battery terminals
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
Sunday, July 22, 2007 4:49 PM
Is it getting fuel ?
brien
89 Z24
Tuesday, July 24, 2007 5:49 PM
Ok so exactly what happends is this
You turn the key in park and it turns over but doesnt start. SOMETIMES (rarely) it will spudder, but wont start.
It is getting spark and fuel. (you can hear the fuel pump hummmm).
Any other ideas?
Tuesday, July 24, 2007 5:51 PM
oh and none of the fuses under the dash are blown.
Tuesday, July 24, 2007 6:45 PM
Just hearing the fuel pump running doesn't necessarily mean that it is getting fuel to or through the injectors. You need to check the pressure at the schrader valve. If you have pressure than you need to get a noid light and check to make sure the injectors are working.
brien
89 Z24
Tuesday, July 24, 2007 7:03 PM
where is the schrader valve?
Tuesday, July 24, 2007 7:22 PM
It will be by the pressure regulator. Looks like a smaller version of the ac service valves.
brien
89 Z24
Thursday, July 26, 2007 12:18 AM
is it possible to push start an automatic cavalier? My cavalier doesnt have AC so it should be easy to find.
Thursday, July 26, 2007 1:34 PM
No. Current automatic transmission cars are not able to be push started.
brien
89 Z24
Tuesday, September 04, 2007 1:07 PM
I HAD A SIMILAR SOUNDING PROBLEM ON MY CAR. IT WOULD TURN AND TURN SOMETIMES SPUTTER, AS IF IT WAS PURPOSLY GIVING ME HOPE THAT IT WOULD START, ONLY TO KEEP ON SPUTTERING AND CHOKING UNTIL I KILLED THE BATTERY.
IN THE END I FOUND OUT THAT IT WAS THE CRANK SENSOR AND THE IGNITION MODULETHAT I HAD TO CHANGE.
I HOPE THIS HELPS!!
Tuesday, September 04, 2007 10:31 PM
Yeah. Crank Sensor did the trick for me.
