should i buy it 2.0 turbo - Second Generation Forum
Thursday, August 16, 2007 12:58 PM
i can get a sunbird 2.0 tubo motor for 100 bucks should i get it its compleat but the heads cracked i got a 1994 2.0 sohc 5speed sunbird
Re: should i buy it 2.0 turbo
Friday, August 17, 2007 6:00 PM
i'd buy it in a heartbeat. new head/headgasket=cheap speed. could run low 14's, high 13's for a grand or so
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
Friday, August 17, 2007 10:39 PM
If I came across one I would buy it to build it, then drop it into my car then sell the one I have (I'd switch the turbos first though).
Sunday, August 19, 2007 1:22 PM
ok thanks for the imput people ill get it where could i find a head for it ive called the local junk yards
Sunday, August 19, 2007 1:23 PM
would i need any of the wiring harness if so where could i find that too because its not in the car
Wednesday, August 22, 2007 12:20 PM
found one for 150 that runs im gettin it friday its got a disturbitor but i think i can switch it over to have coil packs i think i got to change the cam gear also dose any one know
Friday, September 28, 2007 10:01 AM
to go from distributor to DIS, the cranks are different ive head, as well as the engine blocks, ECMs, wiring harnesses, ect. ect. im pretty sure of that, you would also need a new cam carrier... if you dont mind me asking... why get rid of the distributor anyway? not too much of a difference really... i actually like the distributor better myself...
"Hondas are like tampons, every pussy has one!!!"
Friday, September 28, 2007 4:45 PM
im not tryin to thread jack, but i have a similar question, i have 91, 2.0 sunbird, and the junkyard has 2 turbo engines, what would i need off them to put onto mine to turbo it? lol ik a broad question
Friday, September 28, 2007 4:58 PM
cam, pistons, rods, turbo, turbo exhuast manifold, ECM, wiring harness, turbo block (or modify your current one for turbo oil return) and then obvious stuff... piping, ect. ect. id say, just buy a whole turbo engine, with harness and ECM.. it would be much easier than tearing yours down for all this to go in...
