i put a n/a motor in my car so i coudl drive it but it still has the turbo on it. i did all the switching. now it floods the @!#$ out of itself.  should i put the n/a injectors back it it?and take out the turbo ones
UMM. well i guess ill just part it out ..
had same problem once Check wires on starter make sure big black wire is on positive side not negitive side. If this is done wrong it will fill up all cylinders and the engine will eventually bind up,trust me it happened to me.
You can't just put a n/a motor in a turbo car.   They are very different.  You would need to do quite a bit of conversion work.
