clusters - Second Generation Forum
clusters
Friday, June 06, 2008 1:12 PM
was wondering if anyone knew if same year different model clusters are interchangable? or are there different sensors/ connections?
Re: clusters
Friday, June 06, 2008 2:35 PM
Yes, depending on year. There are some slight mods you may have to do, depending on what you're using. What year car are looking to swap what year cluster into?
Re: clusters
Friday, June 06, 2008 2:37 PM
93 manual cluster into the 94 sunbird auto possible? all the guages i think look way cooler .
Re: clusters
Sunday, June 08, 2008 5:26 PM
Yes, its possible. There is a How-To for that in the General FAQ in the General forum on V6Z24.com. It requires some simple soldering.
Re: clusters
Saturday, June 14, 2008 2:21 PM
if they are both 4cyl cars the cluster drops right in, if its a sunbird you might have to change the pinouts behind the cluster on the dash and maybe run a wire for a tach, i have a tach cluters from a 4cyl bird i just havnt had time to change it out
Re: clusters
Saturday, June 14, 2008 7:50 PM
thats the cluster i bought . its off a 93 i dont know if thats a 4 or 6 cyl cluster. where would i run this wire from for the tac??? also what pin outs would have to be changed if you know???
Re: clusters
Saturday, June 14, 2008 9:45 PM
i didnt see it over there . i only saw how to remove , like a pretty generic write up.i know how to remove the old one but when i hook up the new one what wires would i have to run for all the guages to to work? does i run off the ecu? or off of sensors?
