93 SUNBIRD ENGINE REMOVAL - Second Generation Forum
Wednesday, January 27, 2010 10:26 PM
Anybody know if I can use a 1992 2.0 in place of a 1993 2.0 without any major issues? My 1993 Sunbird blew a head gasket and I have a chance at a extremely low km 1992 engine. Also, is it possible to remove just my 1993 engine from the top or do I have to drop the frame out the bottom along with the trans and everything else. Thanks in advance.
Re: 93 SUNBIRD ENGINE REMOVAL
Wednesday, January 27, 2010 11:02 PM
I think the 2.0 SOHCs are essentially the same.
2010 Honda Fit LX
Thursday, January 28, 2010 8:38 AM
Thanks, that is what I figured.
Has anyone removed a 1993 engine out from the top? Or do I have to drop the frame out the bottom along with the trans and everything else.
Thanks in advance.
Thursday, January 28, 2010 7:11 PM
BUMP, someone must have pulled a 2.0 ohc from a 1993 Sunbird! The question is does the engine come out from the top or do I have to drop the frame out the bottom along with the trans and everything else. Or maybe it can be done both ways? (a shop manual i got ahold of says all 2.0 ohc 1992 and up you need to drop the frame and raise the body off the engine?
Friday, January 29, 2010 6:08 PM
You pull all engines out from the top.
Just unbolt it from the car, then tranny, then pull it out.
simple as that.
