So my mom has a 92 cavalier. The damn power door locks are messed up. Question is there any way to pull a fuse or just unplug them from a relay or something i have tried searching and failed to find anything helpful.
you can always disconnect them at the switch on the door panel.
What is so wrong with them that you want to disconnect them?  Just because there is a button there doesn't mean you have to use it, you can treat them like a normal lock if you want; or is something going haywire with the automatic locking feature for when you put it in gear?  If that's the case, you will have to disconnect it at another location (I believe)
You'd need to disconnect the Convenience Module. You'd also the key in chime, the domelight, and some other random stuff. You're better off actually figuring out what's wrong with them.
