So i cant tell if it is the front or the rear, but the driver side makes a horrible sound when going over bumps.  It sounds as if the tire is off the ground and "dropped" back on.  ALl the botls are tightened down to spec.  Is this a common problem with tein SS. is there a way to fix this.  OH yeah the the front is stock tein ride height, adn the rear is "five" notches up.  The dampening is set 14/16, adn this only started after a night of REALLY hard autox.  Thanks
Maybe realignment, whel balance, or something.
Not too sure who else on here has AutoXed hard with their Tein SSs.
Not on a track anyway.
-M
Sounds like my buddie's car when the strut shaft nut wasn't threaded all the way down, had to use washers and buy a deep socket for it.
like said in the other post, most of the problems i had was that at the reccomended height to start... they tried to make em more level.  hence took away the rake angle a bit.
secondly, at the recommended height, the axles were dipped, meaning they were below parallel...
so i raised both sides, accordingly about a bit over inch on the threads... 27mm to be exact.
no probs, driving hard, and even did some testing in a local empty lot the past few weekends... basically autoX conditions and the same speeds....
also the way i made sure the axles were level was to have it on a drive on type lift and raise it to eye height.
thanks event, what is your settings for front and rear, im goign to take it inthe garage this weekend and redue the ride height thansk again!
6 front 8 rear daily, 12 front 15 rear track.  11 front rear 13 with rear tie bar.
what abotu your die height, i guess its time to lower my dampening it is way high, 14/16
i dont wanna die....yet.
ride height.  axles in front at parrallel, and in the rear about 3/4 inch higher.
