I'm going w/ Koni Yellows with Ground Control, and I got 2.25 piping, will my pipe scrape........Also I got 18's with 215/40/18 Falken Ziex....and from searccing on the org. I believe those will fit if lowered w/out any mod.s, right??? Thanx!
it shouldnt because u can adjust the oilover so that it wont and from what im told the rims will be ok
We dont know how the pipe on your car was run.
Sence its custom it could have been run closer to the swing arm out back than the stock one was.
When I bagged my car my 2.25 was way to close. I took it back and they built 3 dif rear sections before they finaly got it right so it would clear.
I am all that is man
it could, i have scraping right now because morons at Monroe cant weld and they all busted
Thanxs for the replies.....I'm going to knock on wood and hope that it don't scrape.
my rear beam hits my exhaust cuz i wasn't lowered when i had my system bent and the guy didn't give it much clearance. i'm dropped on goldlines and konis
strat81 wrote:my rear beam hits my exhaust cuz i wasn't lowered when i had my system bent and the guy didn't give it much clearance. i'm dropped on goldlines and konis
I have (had) the same problem. Mine was just barely touching, so it would rattle and was really annoying, so I wedged in a thick piece of rubber ghetto style and it lasted 3 years lol.
Rob
Sold 2/2/05
i actually plan on having a 2.5" system bent up this year by a different shop that does awesome work...
Wow almost a year dead. Anyway, I dropped on koni yellows and goldline springs and every once in a while my resonator will scrape the ground. It started out as the rk sport single exhaust but, I haven't changed any bends so you should be ok. I has never hit anything else.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Wow,dude thankz for the tip...........one year later
..........but my exhaust pipe fell of going 75mph on the freeway a couple months ago, from a bad weld, oh well.
