Hey Guys
I need your help on something how you guys stop wheel hop what kind of stuff do you use to stop it? p.s this is going to be on a 1996 sunfire
Opening Soon Kustom J's
some say control arm bushings help
control arm bushings will help, having stiffer springs, and struts will also help.
are you drag racing it?
-Chris
Bushings would be the first thing I would change: upper and lower motor mounts, tranny mounts,  control arm bushings, and sway bar link ends.  After that stiffer springs and struts. Sub frame connectors also reduce chassis flex, which may reduce wheel hop.
Heavier wheels help.  I went from stock 14" steel wheels to alloy z24 wheels, and wheel hop is almost non existent now.
Control arm bushings do help, but be sure you have access to an arbor press or the know how to install/remove bushings on your a-arm.
Stiffer springs definatly help as well, after I put on my H&R's and the prothane bushings I have no wheel hop anymore.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
flat low-profile tires...like a 205/40/17  that also helps it a lot, and lowering springs...such as eibach sportline springs...or whatever the lowest ones are, that is what I have, and there isnt any wheelhop here.
any recomendations for brands and models of these parts? im getting mine ready for the track again and want to take care of this before it starts again. thanks
2004 Cavalier, 2.2 ecotec, 5spd getrag
do you ever notice that the ones who talk the loudest have the least to talk about?
