ok. so i had got dspecs over the winter along with springs. and im also buying new strut mounts just so everything is new for the switch with stock suspension.  now i have the rear strut mounts so i put them on and was just testing them in the house by pushing down  on them to see the difference when adjusting...    1 of the rear ones moves very freely at 5 turns from full hard, but the other one still seems rather stiff and slow decompressing. what i want to know is do they need to be broken in before they start working and compressing/decompressing properly, or could there be something wrong? after finding that i also tried both fronts just by pushing down the strut bar and both fronts seem rather stiff and just slightly less stiff when at 5 turns from hard. nothing compared to the one rear one that moves like what i would assume they all should..... im kinda confused :S
I've got D-specs, but I didn't try your test though.  I haven't had any problems with mine, and I'm currently running a 3/3 setup.  I'm using Goldline springs.
I would say that the one is bad, if it didn't behave like the other 3, and it was adjusted just like the other ones.  I'm no expert though.  hopefully someone that's more knowledgeable will answer up.
Desert Tuners
