Well after a few days of frustraction cuz lowes fittings are crap i finally got the quick connect fittings that the easy street kit comes with for my whole kit and now i believe everything is perfect. (knock on wood ) My tank and bags hold air with no problem.
I have had the air line for my drain and air horn bust because the fittings i got from lowes are crap. They probly aren't crap just hard as hell to use and put on so i say they are crap.
I also had the idea of putting ball values on my air horn and drain line so if the line did get busted i can turn it off and hopefully it won't leak on me.
I believe picking up fittings and extra hose i have another 60 - 80 bucks in it. If i could take back the fittings i don't need now i would but lowes i am sure won't take them back
Believe now i am going to get all steal breaded lines now. Found a shop that i can take my air lines to and they will make me lines
In my experience Lowes has always had excelent products, maybe too hard for some to use, but excelent none the less.
And they always take things back if it's defective or unused (or they can't tell the difference).
i order all my fitting from either easystreet directly or through jason at airbagsource.com. i only go to home depot if i need a reducer or something small that i need right away. if i can wait a few days i'll usually just use jason or easystreet
im lucky i have a parker fitting store in my town.
C.T.S wrote:In my experience Lowes has always had excelent products, maybe too hard for some to use, but excelent none the less.
thats probly it. Just don't have enough exp. with air lines on how to put them together. I thought i had 2 good connections on my tank but when i moved the line some it popped on me.
So i just went with the quick snap kind that easy street gives you.
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]i order all my fitting from either easystreet directly or through jason at airbagsource.com. i only go to home depot if i need a reducer or something small that i need right away. if i can wait a few days i'll usually just use jason or easystreet
same here but he's sponsoring me so i try to send all my business thru him if i can
^^ boo he doesn't want to sponsor me...
