Does anyone have the part number for the bolt needed on the swaybar install on a barless cavalier? I wanna go to the dealer and order it. I'm gonna be gettin a Addco front bar and would like to have all the stuff for when I go to do this.
Bracket, Stabilizer
95-99 R/L 22587935
00+ R/L 22660396
and the bolts to mount
I was lookin into the addco sway bar. I think it come with the brackets, bushings, and endlinks, I just need the bolt or bolts to get it put on.
that I know of the bar comes with the bushings but not the brackets you need to get those either from gm or junk yard.. the part number is 22660396. and take your time doing the install it is involved . you will need lots of patience as I found out. here are some instructions I found here on the org.
FSB Install - Same regarless of engine:
1. Jack up car, take off wheels.
2. Pull lower engine mount, and driver's side support (subframe to radiator).
3. Pull 6 subframe bolts and lower subframe carefully (had to pull mine to get it down actually).
4. Pull 2 bolts for old sway bar, and 2 endlinks.
5. Replace sway bar, it fights you but it will fit.
6. Reverse of above to put it back together.
if you have any questions email me.
