Any body have the rk sport dog bone in poly instaled with pics. I am going to order mine soon and just want to know what you thought about it. Also what are the torque specs on those bolts. this is for a 97 sunfire gt
http://www.overkillengineeringmotorsports.com/
yeah its easy. support engine with a jack. remove bolts that hold mount in. replace with dog bone, torque down as tight as you can. done.
put a piece of wood between the jack and engine. And yes, it is just that easy
Best quarter mile to date - 15.750 @ 85.82
"We ride together, we die together. Bad Boys for life"
Nimbus 9, some friends of my that rock! Click and experience them for yourself
you dont need any jack
remove the 2 bolts
install the dog bone
reinstall the 2 bolts
Get them from Karo at CarCustoms....free shipping and I've always had good experiences with him.
I need a sig...I need new doors first.
Ok the bolt on the right is what? I am kind of confused by your post. The nuts are welded so they cant be torqued. Also there is a bolt that attaches to the engine and a bolt that attach to the sub frame.
That's straight from the GM manual.
I accidentally copied one too many things and left out a hyphen
Should just be: Engine Mount (right hand side) to the Body Support - Bolt
Right hand side is referring to the passenger side. Same torque specs for both bolts.
You're normal tight is about right. 32 ft-lbs isn't that much, but it isn't loose. No jack necessary, I've never used one.
you dont have to use a jack but its still not a bad idea.
Also where is the upper mount pass or driver side?
Its on the passenger side
Lower mount:
Upper Mount Insert:
this might help as well. Its the actual RK Mount
Wow that looks like it does alot. Whats the procedure for the upper mount. If I take it of with out a jack underneath the car do I risk the engine mis aligning. I am definitly going to order those two parts right now.
i used a jack just to insure the motor wouldn't move. its just that one extra step to be safe on.
As far as the upper mount goes...
you just remove the 3 bolt plate around the mount. (2 on top, on under coolant tank) Then slide in the insert. But you have to a good stock mount in. It can't be busted.
TurboTechRacing has just released a new mount for the 2.4's! It looks to be much better, and a little more eye candy under the hood. Check it out. Its a full replacement instead of just a insert.
Full Cav Effect (stenger) wrote:i used a jack just to insure the motor wouldn't move. its just that one extra step to be safe on.
Yes and the "insert" still has A LOT of play compared to our Turbo Tech Racing solid engine mount, which is a 100% complete replacement mount. The Turbo Tech Racing Mount has alomst zero movement, yet has very little vibs within the car.
-Aaron
www.TurboTechRacing.com
go with his full replacement. you wont be dissapointed. can be coated almost any color you want. the car customs one is the prothane insert. the one from turbo tech racing is a turbo tech racing brand.
