I got some adjustable coil overs off of ebay, but the problem is the coils are 2.5 in. in diameter and my stock coils are are like 5 in. in diameter. Also my instrcutor also told me that since their not the same size the bearing in the strut mount will not connect to the bearing and the coil will not work is this true. or will these coil system work.
what did you buy? im assuming some crappy coilovers. also they do not go on stock struts. it seems like you got a cheap set of coilovers that didnt come w/ all the correct parts
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]what did you buy? im assuming some crappy coilovers. also they do not go on stock struts. it seems like you got a cheap set of coilovers that didnt come w/ all the correct parts
pretty much covered it. buy cheap, get cheap results.
Yeah, you probably bought something you can't use. Do your research first next time.
But to give the benefit of the doubt... post up the brand name or some pics of what you've got and we'll give you a more informed opinion.
