Abs Problem.. - Suspension and Brake Forum
Abs Problem..
Friday, January 26, 2007 7:19 PM
ok not sure if this should go in electrical so mods please feel free to move this thread.
the problem is that i just lowered my car and took the fenderwells and all the plastic guards out to clean while i was doing this..... well i moved the car and the abs wiring harness got caught under the wheel and was pulled apart....the problem is i dont know where the other half of the two wires is or if it just got pulled from the harness plug...this is the right front by the way.
Re: Abs Problem..
Saturday, January 27, 2007 3:54 PM
anyone?>
Re: Abs Problem..
Saturday, January 27, 2007 6:33 PM
Pictures of this would help probably, possible to get any?
1983 Camaro Z28
Re: Abs Problem..
Sunday, January 28, 2007 8:13 AM
Start by taking the plug end apart and seeing what's in there, so you know what the other end should look like.
Know how to solder? If not, you might want to check the regional section for someone near you to help.
Re: Abs Problem..
Wednesday, February 07, 2007 4:57 PM
well the problem is...the wire has been ripped apart....and i dont know where the plug is...if i knew then i could just find where the circuit is broken and just splice them back together....ill try to get some pics in a few minutes
