GR2's oil on casing? - Suspension and Brake Forum
Friday, February 02, 2007 8:57 AM
I bought a brand new set of KYB GR2's, should they have oil on the outside? Is that to prevent rust, or do I have one come to me blown already?
Re: GR2's oil on casing?
Friday, February 02, 2007 9:37 AM
Alot of times, oil get spilled on the casing in the manufacturing process. It should be ok. Stroke it a few times, if it returns on its own, its ok since the gas will always leak out before the oil will.
Go Go OG Traction!!
Friday, February 02, 2007 9:42 AM
all stocks have oil on it to keep it from rusting.
<a href = 'http://ivpnewmedia.com/10thst/tifts/'>
<img src = 'http://ivpnewmedia.com/10thst/tifts/dpBanner.gif'></a>
Friday, February 02, 2007 9:45 AM
They all have pressure to them, like when I take the band off of them they want to shoot up.
Friday, February 02, 2007 9:54 AM
They are fine
Go Go OG Traction!!
Friday, February 02, 2007 10:08 AM
weird i didnt have any oil on mine. they sounds fine though
Friday, February 02, 2007 12:41 PM
^^^^^ i was hoping you'd pop on cause i knew you had a brand new set of gr2's. I'll double check them all and see what's up with them when i get home.
Friday, February 02, 2007 1:19 PM
yea cuz i checked all of mine when i got them in the mail. their still in the box with the band on them but i check to make sure they were the right struts and mine didnt have oil on them. if you take that band off and they shoot up like that, if you try and push them down and they give you resistance then their still good
