Clearance issue front anti-roll bar. HELP? - Suspension and Brake Forum
Wednesday, February 07, 2007 8:42 AM
Okay sway bar is in but it is very close to the passenger side axle coot. It actually makes contact with the clamp that holds the boot in place. The picture shows this pretty clearly.
Any suggestions to correct this are appreciated. Should I grind off some of the bar or is there any other fix? The drivers side is fine.
both end links are strait up and down. Unless I have the bar in backward?
Thanks for any help.
http://i79.photobucket.com/albums/j130/mykeln/mysig.jpg
Re: Clearance issue front anti-roll bar. HELP?
Wednesday, February 07, 2007 11:33 AM
I would loosen the sway bar mounts in the center and slide the bar to the drivers side about 1/2 inch to an inch.
Thursday, February 08, 2007 4:00 PM
Any one else? Can't wait to road test once I get ther rear one in along with the AGX's.
Thursday, February 08, 2007 4:03 PM
its red so I assume its the Eibach pair?
switch the end links with the rear bar. I had the same problem.
Thursday, February 08, 2007 10:04 PM
Darkstars wrote:its red so I assume its the Eibach pair?
Thanks for the tip. I opened the bag for the rear bar and used that set of end links. No interference at all. On Monday I will tackle the rear bar as well as installing the AGX's and new shoes and drums.
Friday, February 09, 2007 7:51 PM
glad to hear it worked, I figured that was the issue. I called Eibach about it one day and they basically said they were gonna tlak to someone and call me back within an hour.... its been liek 6 monthes hahahaha
Friday, February 09, 2007 11:03 PM
hmm , the g/fs does that too , only hits on hard turns to 1 side
i thought i had remembered hearing about them being switched , forgot all about it , LOL
