Can someone measure how long the gauges are im making a glass dash and need to know, the length of the eastreet air gauge.
thanx
uhh no clue but why not just get the gauge out and test fit it
My car is in storage been there since last sept, and i have no access to it.
Can someone measure them please..
I can measure them for you in a little while.
Please do so, sooner the better.
thanx
Jon
They are 2 5/8" from the face of the gauge to the tip of the fitting for the air line, hope that helps you man.
dual needle from the mounting flange to the longest part with the supplied fittings is 3 1/4"
single needle is 2 1/2" from the same points
I need the dual needle measurment, and also need it from the front of the gauge to the end of the fitting where the air line goes.
Anyone? I need a accurate one.
id take a measurement for you but my gauges are not with me. 3 1/4" sounds about right though because those gauges are pretty long
Yeah, I measured the single needle not thinking, sorry man.
I cant go ahead with a non accurate measurment, im glassing them to the dash so cant make a mistake.
irssunsittinlow wrote:dual needle from the mounting flange to the longest part with the supplied fittings is 3 1/4"
thats your answer though. the single one is shorter. maybe Sdwndr2 read the tape wrong because 2 1/2" and 2 5/8" is only an 1/8" different.
From the back of the fitting to the very front of the gauge, just over 3 5/8"
From the back of the fitting to the back lip of the front of the gauge, 3 3/8"
Hope that makes sense.
www.TaillightTinting.com #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
