what air ride valve are you using? - Suspension and Brake Forum
Sunday, March 18, 2007 8:46 AM
here is my question!
i wd like to know ,what brand of air ride valve are you using and they are which size?
thanks you!
Re: what air ride valve are you using?
Sunday, March 18, 2007 9:14 AM
3/8" air lift 300psi
Sunday, March 18, 2007 11:03 AM
Air Lift/ Easy Street 3/8 Manifold valves.
I was torn between these, and 4 ~ 1/2 SMC Valves (lift) and 4 ~ 3/8 SMC Valves (dump)
But the Manifold valves work very nice, they dump semi quite (if thats what you want). The rears are super fast up, and fast down But if you want to slow them up, you can put flow controllers on them..
Sunday, March 18, 2007 11:08 AM
run the smc they r fully rebuildable if anything does goe wrong with them i have had them for 5 years and no problems depending on speed and wht you want to do with it go 3/8 if you want a decent speed go half if you want it quicker
Sunday, March 18, 2007 12:04 PM
smc are good, and if your piecein a kit together and not buying the easystreet kit and need valves i recomend the smc's also
