above are pics of my pass side half shaft. I replaced it because it was making a ticking noise, Art suggested that it might be on its way out so i replaced it. The only thing i could see wrong with it was that the boot closest to the tranny had A LOT of play in it. like i could really pull on it. so you think a pin or somethign came loose or what? BTW i cut the boot open to look in, didnt see anything missign course there was a lot more grease than i thought there would be.
o and the first pic is of the hub bolt i almost stripped. T55 torx bit in case you were wondering. always use the proper tools, a allen wrench will not do the job.
Edited 1 time(s). Last edited Monday, April 09, 2007 5:02 PM
did you get it back together does it still make noise?
no, odd thing is it stopped making npoise for awhile but i had already bought the half shaft so i jsut replaced it anyway. better safe than sorry.
btw i jsut included pics because i felt like taking them, no real reason.
mine makes a slsight tick     just 1   when i turn right and when i turn back to center     whats that caused by  halfshaft as well?
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
That play is pretty normal I believe.. the ticking noise, probably just a bad joint in the shaft is my guess.
 1983 Camaro Z28
1983 Camaro Z28
