I did a search and found nothing,I just need to know are all cavalier and sunfire springs interchangeable (lowering springs) like skunk2,Dropzone,progress,intrax amd etc...
Thanks
Yes they should be
Only difference in the stock suspensions were the top mounts i believe
top mounts are the same... with one exception, in either 99 or 2000, the design changed ever so slightly. the bottom of the mount remained the same, the top had the design change. So depending, you would need a spacer/washer between the mount and the nut on the strut shaft.
Thanks Guys.. has anyone used drop zone springs w/ 1.8in the front and 2.3 in the rear? just wondering how it looks..
Thanks Eddie
they look good, ride better than most lowering kits, handle worse than most lowering lits and wear out A LOT faster than most struts designed for lowered cars.
A nice starter set, but I replaced mine with a higher quality kit. i have a really small crappy pic in my profile from when i had them on if you want to look.
drop zone is garbage. i wouldnt even use them to hold up a coffee table
That change that Kardain is talking about was done on both Cavaliers and Sunfires.
All 3rd gen j-bodies (Cavaliers and Sunfires) share all the same suspension components. As mentioned, a change was made to the front mounts for 2000, but that's about it.
