Does anyone have a picture of a sub frame brace installed on a 2.4? I would like to see where it mounts before i install mine. Thanks
suspension forum
performance is for motor stuff
I have to drill the holes right? Its not just bolt on correct?
Honestly, it's been so long since I've done the mod, I can't really remember.
But I believe you do have to drill the holes.
Just use the holes on the subframe base as a template but make 100percent sure that you have it centered or you'll have a real hard time getting the nut/ bolts tightened.
Good luck.
It's a mod that you'll feel the difference.
Also be wary of things in the middle of the road. The bar sits a bit low so do be careful with straddling something in the road.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
Misnblu wrote: The bar sits a bit low so do be careful with straddling something in the road.
Ha ha i have that down pretty good, My camaro got long tube headers with 3 1/2' pipe. not a good sound when you straddle a dead cat in the road!!
yes, you do have to drill holes, i had to pull the lower motor mount to make things easyer. but it was in all a 30 min job. very easy, and a large improvement. i cant wait to get my new sway bar on!
