first brake upgrade on 05 J - Suspension and Brake Forum
Monday, May 21, 2007 4:51 AM
i just bought some brand new slotted/crossdrilled rotors and brand new axxis pads from www.smgmotoring.com and i did a search and came up with this:
1) jack car up
2) remove tire
3) 3/8" allen key (2 bolts on the back of each caliper)
4) remove caliper
5) compress the caliper with the old pads still on (i find it easier this way and use a "C" clamp but they make tools for brakes)
6) remove old pads and replace with new ones
7) pull rotor off (nothing holds it on once you remove the caliper)
8) put new rotor on
9) put caliper back over new rotor
10) tighten the 2 bolts for the back of the caliper
11) put tire back on
12) lower the car
13) pump the brakes back up
if you dont remove any brake lines or open any then there is no need to bleed the brakes
is there anything else i need to do, i read something about lubing the caliper pins???
thanks for any and all help
You take a women and X her by PSI devide the legs and you can then juice the car......LOL
Re: first brake upgrade on 05 J
Monday, May 21, 2007 5:50 AM
i think thats the write up i actually did. thats the basics of it. some people will recommend to grease the slider pins (thats the 2 3/8" bolts on the back of the caliper). the rotors may be stuck on the hubs so you may need to get it a good whack to get them off. thats really it. pretty simple/
Monday, May 21, 2007 6:30 AM
i don't have to have the rotors turned do i?
thanks for your help
Monday, May 21, 2007 6:52 AM
nobody will turn sloted/drilled rotors
Monday, May 21, 2007 8:07 AM
lol ok, i don't know alot about turning rotors, but why is that and whats the purpose of it, and how long do you think these rotors will last?
Monday, May 21, 2007 8:50 AM
You don't machine new rotors. People machine old rotors to resurface them and get rid of any high spots when they're going to reuse them. These days though it's often cheaper or only marginally more expensive to just buy new ones.
I definitely recommend cleaning and re-greasing the sliders. You might as well, while you've got the calipers off.
Monday, May 21, 2007 11:30 AM
Do not forget a thin layer of grease whereever the pad touches the caliper to prevent sqeaking.
Tuesday, May 22, 2007 4:00 PM
thanks guys for all the comments, i'm so excited to put them on can't wait for them to get here
Wednesday, May 23, 2007 1:24 PM
Don't forget to tie the caliper to something after you take it off. Don't let it dangle by the brake hose.
Compress the caliper before you take it off the car. Since you are throwing away the old pads and rotors, you can use a screwdriver between the rotor and pad. Of course, a c-clamp is preferred, if you have one already.
You sound like you are fairly new at working on cars, so don't forget the basic safety stuff like jack stands.
Wednesday, May 23, 2007 1:45 PM
So you got your stuff from them?
How lon gwas the turn around time to get your goods?
-M
Wednesday, May 23, 2007 3:37 PM
You need to grease the pins, or the calipers could get stuck, burn up the pads, and prematurly wear the rotor away. I've seen it, thats why I'm saying it.
Caution: Redneck Posting
Monday, July 30, 2007 11:07 AM
just an update i finally got my brake package i'm putting them on tomorrow wish me luck
Monday, July 30, 2007 11:19 AM
damn it took you that long to get your parts?
Monday, July 30, 2007 5:58 PM
It took almost 3 months to receive my parts!!!!!!!!!!!! It was rediculas their very quality parts and customer service was great but the whole shipping crap was horrible!!!!!!!!!!
Tuesday, July 31, 2007 5:21 PM
Good luck with the install. It's pretty simple stuff except sometimes those rotors can seem impossible to get off. A sledge and block of wood will take of it though.:-)
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
Tuesday, July 31, 2007 8:04 PM
ECOTEC wrote:Good luck with the install. It's pretty simple stuff except sometimes those rotors can seem impossible to get off. A sledge and block of wood will take of it though.:-)
I would have thought this about the drums, the rotor should be easy grab it at 9 and 3 o'clock rock it back and forth and pull it off.
Wednesday, August 01, 2007 4:30 AM
sometimes its not that easy. i just did my brakes a week ago (just replaced the pads) and the passenger side rotor came off pretty easily once the caliper was off but the driver side was stuck on pretty good.
Wednesday, August 01, 2007 4:45 AM
Darkstars wrote:nobody will turn sloted/drilled rotors
Dont know where you looked but i got my powerslots turned
