How do i install a rear strut tower brace? The front one was easy but the rear one has a flat round nut on it. Im wondering if i have to undo it from the wheel well or if there is another way to undo the nut.
My rear brace only has two holes for bolts. I undid two nuts on either side, put the brace on, then put the nuts back on top.
if you are talking about the welded nut, you just have to put a spacer on the other bolt to even it out.
Here's what it should look like to make it level.
This should help you in seeing how it goes onto the rear.
Good luck.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
I know this is an old thread but i was wondering if anyone had any pictures of the rear brace with the carpet still in? Also a full trunk shot. Thanks.
xell wrote:I know this is an old thread but i was wondering if anyone had any pictures of the rear brace with the carpet still in? Also a full trunk shot. Thanks.
i hope this is what you were asking for..
http://corpsemangler.fortunecity.com
It definately was thanks a bunch!
