i just got my Koni yellows yesterday and I don't understand something...
They don't have any plates for the spring to sit on ... and how do I get them to bolt on the suspension arm in front ??
I am a noob with these shocks.... and it dosen't seem right !
Ok I figured it out !! you have to cut the existing shock and slide the koni in !!
yep, the koni instructions blow ass so just use the search here and you will find TONS of info on how to do it if you cant figure something out.
Rollin' on question marks since 07.
For the rear ones, you take the perch off the stock struts and it slides right on.
You're going to need to drill out your rear mounts as well.
Full instructions are here. You'll definitely want to read through them before planning your install to ensure you've got all the tools you need and what not.
http://www.wildweasel.ca/HowTo/Auto/J-Body/KoniSportInstall.aspx
