Hey people, I've been working on another project, and I'm getting to the final stage. I should have definitive pricing on these in a few days, but I wanted to throw it out there for interest:
I have been working on a redesigned spindle based on the N-body aluminum unit, that will use the standard J-body hub, and maintain proper geometry. I have nailed down the design, and have found a foundry to cast them and do the heat treating. They will be made of 6061-T6, and will also be properly machined for J-body ball joints and steering links, so installation will be extremely simple.
The benefits are that you do essentially the NFW swap, but retain the bolt pattern. Essentially, you'd be cutting weight, and getting 12" brakes with dual piston calipers, and for far less than any of the kits made so far for our cars.
I am also working on the rotors for this, but for the time being, redrilled W-body rotors and centric rings would do the job. I can take care of both.
The cost of these per pair will be in the range of $150-200 per pair.
What would be the interest in these?
Edited 1 time(s). Last edited Friday, September 26, 2008 8:45 PM
IT would have its place in those of us who wanna do NWF for looks, but for performance I see the weak link becoming the wheel bearings, plus that means you also keep the J body outer CV, another weak point in the driveline.
No question it would be cool, but it seems something like an NWF with redrilled W body bearing assemblys and CV's would be more suitable and just using the stock W body parts as well as costing less and being a tidbit stronger.
Just a thought.
It would make the NWF an easier setup and cheaper too since you would not have to worry about a new set of wheel bearings and CV axles from the W body, however so I could see it definatly having a place.
This could be interesting. Possibly for the DD, I hate these stock brakes.
I would be interested, but my current set of rims has a universal 5 bolt pattern on it, so 5x100 and 5x114/5, thus I have no need.
BUT I feel it is a terrific idea !
My Cav
I give up...
How do the brake caliper mounting points change from J body to N body?? This would be nice to add to my Wilwood's but the brackets are made for a J body spindle
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LD9 for Life
but wouldn't you have to redrill the rotors for the bolt pattern
Are you ready to accept responsibility for this if one of these spindles, a part of a car that holds together many many many important things, fails?
It is this reason that over the past couple years I've stopped thinking of stuff to make for the car world.
So the only thing you are doing is removing the caliper ears/bolt holes and adding an area for two bolts to hold the caliper bracket correct? Out of curiosity, how did you get the dimensions for the stock spindle? I understand that you can get a mold from a modified spindle and go from there, but you still need certain critical dimensions for the bolt hole locations.
I'm guessing that these wouldn't fit with the stock 16" Z24 rims....
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
^^Well that's good news. If they manage to clear the 16" stockers, I would very much consider getting a set.
1997 GMC Sierra
2005 Honda TRX450R
Well, then I wish you the best of luck.
Quiklilcav wrote:Cursed Cav (Luke Heier) wrote:I'm guessing that these wouldn't fit with the stock 16" Z24 rims....
I am going to try to make sure they will clear factory 16s. There are no guarantees with this yet, but think about this: the NFW swap will clear the factory 16s from N-bodies and W-bodies, and I'm pretty sure these will clear the J-body rims, because the caliper does not stick out much from the mounting face of the rotor.
As for this quote, I highly suggest you look again at an F-body 16" with rotor and caliper, and a J-body 16" with rotor and caliper. They are
completely different animals in the amount of spacing that there is between the rotor, caliper, and inside of the wheel. You're gonna be
very hard pressed to make this work with a 16" stock J-body wheel.
Short Hand wrote:I would be interested, but my current set of rims has a universal 5 bolt pattern on it, so 5x100 and 5x114/5, thus I have no need.
You will once you get a flat on the front in the middle of nowhere and have to pull a rear wheel, move it to the front, then put the spare on the rear....
Quiklilcav wrote:Viper98912 wrote:Quiklilcav wrote:Cursed Cav (Luke Heier) wrote:I'm guessing that these wouldn't fit with the stock 16" Z24 rims....
As for this quote, I highly suggest you look again at an F-body 16" with rotor and caliper, and a J-body 16" with rotor and caliper. They are completely different animals in the amount of spacing that there is between the rotor, caliper, and inside of the wheel. You're gonna be very hard pressed to make this work with a 16" stock J-body wheel.
I know what you're getting at, but this setup is built around the NFW swap, except that I am replacing the hub with the J-body hub. This is requiring a slight modification to the offset between the hub mounting face and the caliper bracket mounting face (the J-body hub has a taller height if you measure hub face to spindle face -- 8mm difference, to be accurate). The rotors are going to be the W-body design, with the exact same hat offset. I'll pull one of the NFW assemblies in the house and take a picture to show what I mean. The caliper really doesn't stick out much at all.
If it comes down to it, I may, depending on cost, have the rotors built with a slightly higher offset, and push the caliper mount back a little bit.
You can change the hub height all you want; you haven't changed the rotor height (as you stated at the end). Building and machining custom hats will cost a lot that most people with Jbodies won't buy. For that, it's cheaper to buy a Wilwood kit. A close look at a stock 16" proves that the inside profile of the spokes curve in A LOT, like if we had deep dish-lip wheels. This occured across all wheel lines, with the 95-99 Z24 wheels having the least amount of curve. There's
absolutely no way you're going to fit a 12" rotor and caliper with the stock wheels without some other modification. If you could've, then I would have not bought my aftermarket 16's for my NW 12" front swap. And NW wasn't the first swap I considered - custom bracketing was. I've been there.
You've also introduced the fact that now people will have to redrill the holes for the W rotors - which if they buy hub rings to hold the rotor, then they can do this with a drill. If not, they they'll have to have it done by a machine shop, while still "needing" rings. If you provide this for them (at your cost), you've now introduced about $25-50 more into your price just for the fact that you added a lot of weight to your shipping costs - you pay for the shipping to get the rotors to you, and then you pay for the shipping to have the rotors shipped to your customer. The best way is to always stay out of everything - aka you supply the essentials and stay out of the rest. Especially now with plain, dimpled, slotted, crossdrilled, both, coated, non coated, and even damn real gold plating out there available for people's rotor preferences.
Ask any of my personal friends and they'll tell you I've been around the block when it comes to brakes for the J-bodies. This is why I came to post in this specific thread, because it intrigued me (I don't post much anymore on this site). I've also stayed out of the Wilwood rear thread because I don't believe it's going to reasonably work. I do commend you for trying to find/create another setup. Just make sure you've got it
very well thought out, before you get yourself into a situation.
Edit as you posted a picture while I was posting -
1) You have 13mm from caliper to rotor hat. Tell me how many you've got on the stock J-body setup, because you're gonna be surpised.
2) The LS Sport wheel is
somewhat flat on the inside, except that the wheel height before the spokes is almost non-existant, nearly hugging the caliper for comfort from the rocks.
For good measure, to make my NW 12" setup work with my 01 Z24 stock wheels, I would've needed approximately a 1" spacer. That's also not using an F-body caliper, which is slightly larger.
If you change the steering arm, make sure there's enough thread space on the tie rod for change in distance. And then you'd need a new alignment for your grossly overdone toe.
2-piece rotors are much more expensive than stock ones I can buy at Autozone. They sure do look and perform much better though.
You can't change the hub height too much because then you'll have axle issues (binding or coming out of the tripod), especially when turning at full lock.
You can't change the rotor height too much with custom hats because then your caliper will be too far out or too far in, hitting your wheel or knuckle.
I'm gonna have to start asking you for a % cut for all this consulting I'm providing you to make your product better.
Viper98912 wrote:You can't change the rotor height too much with custom hats because then your caliper will be too far out or too far in, hitting your wheel or knuckle.
I know. Seriously bud, have some faith. I'm edumacated.
I'm talking about possibly 10mm, and there is plenty of room for it.
A guy at work always tells me state the obvious. Not because he's being obnoxious, but just because it will always make the situation more clear. You know, like ensuring you use the blue marker for the marker check when you're checking the parts that you have to use the blue marker for.
But as for your 10mm, I'm assuming inwards. IIRC there's about 2-3mm of gap between the rotor and the ball joint when the car is on the ground. In my case, I had some really fat ball joints that I even had to slightly dremel to get any gap. The rotor had an auto-ebrake (the rotor crushed against the ball joint). So pushing the rotor inwards isn't going to be easy either.
And also, there are different versions of the aluminum knuckle. I think there is a slight hub height difference between them, because I had the rotor/ball joint rubbing issue whereas many others have not. You can tell the difference by looking at the tie rod arm.
