I am going to be replacing my entire suspension setup (minus the Eibach Pro Kit springs) soon and I want to make sure it's done completely right this time around. The setup will consist of KYB AGX struts, Eibach Pro Kit springs, KYB '95-'99 front strut mounts and HT Motorsports solid rear strut mounts.
I already have in my possession
KYB front strut boots that came with bump stops. Now I am in the process of trying to find strut boots and bump stops for the rear. Auto Zone has a ton of
strut boots and
bump stops, but I can't for the life of me figure out which ones to get because they all seem to be universal. The guys that work at my local Auto Zone are totally useless and I don't trust their information one bit, so I am turning to the J-Body suspension gurus here on the The Org. to help me out
. Thanks in advance.
After doing some reading on here I have discovered that pretty much everyone is just using factory bump stops for the rear. I searched around on GM Parts Direct and came up with this number for the rear bump stops:
#22129486. I would appreciate it if someone could please confirm that this part number is indeed correct for the rear bump stops.
So, I guess what I am going to do is go ahead and order new bump stops for the rear from GM Parts Direct and order
these strut boots for the rear.
Does this sound like it will be okay for the rear? Thanks in advance.
