has anyone installed these on a 3rd gen yet?      i did mine tonight,  but for some reason I cant get the torque right.      the spec for GM links say 17lb-ft  but the nut on the moog's just keeps turning  to the point where it looks like its pinching the bushing.
the ride has improved in both  noise and steering, so I think this set up might work
any info would be appreciated
Respect...
general rule of thumb with end links, tighten them till the rubber bulges out to be the same size as the metal washers
Darkstars wrote:general rule of thumb with end links, tighten them till the rubber bulges out to be the same size as the metal washers
Thats how its done, you done want to over tighten them to where the bushing is bulging out, but you want it to be the same size as the washer.
That's pretty much what I did;  but I'll check it again tonight after some more Klicks.
I actually counted the threads on the end of each link bolt,  to try to make them even LOL!
Thanks for the info.
