Last week I replaced both front and back struts and springs with the Tokico hp kit.
I also used new monroe strut mounts all around.
Ever since I installed them I get a rattle noise in the fronts,only going over bumps but goes away in turns.
I used aftermarket boot kit and bump stops,but I'm not crazy on how they fit once they were trimmed.
When I bounce the front end,I do get a noise almost like there is a little play between the mount and the spring.
I used the isolators,and everything seems assembled correctly.The top nut is tight.
I just had one of the struts out again,and when I compress them,there seems to be a little play.
What is everyone using for boot kits,stock or after market?
Because the stock ones actually sit in the mount itself,and the monroes have a different setup than original.
Can the sway bar links cause any odd noises?
I appreciate any suggestions,cuz I'm banging my head trying to figure this out.
anything can make a rattle noise. without seeing it i cant say for sure, but i can give you some things to look at.
#1 would be to try to tighten the top nut on the strut more.
#2, check your link pins as stated, they can make noise.
#3, what do you mean by "play" when compressed??
