Ok where to start.. I found a set of 99 alero control arms for $35 a piece.  These should be the aluminum ones correct? I have yet to call the place to ask if they are. If not i will call some of ther yards. Now i'm going to cut them down to j-body arm spec's. Now i also want to do the N+F+W body brake upgrade. So can i use the aluminum spindal found in the 99's with this swap? that would mean i need to use the lower alero ball joints for 99 right? Also i'm not sure on the wheels i'm using. They are 100x5 and then a bigger size but not sure as to which that is. From what i gather it is 114.5 but i'm also not using hub centric rings. So will these work with n-body hubs?
Now comes some info on the brake swap. I usually hang out on ls1lt1 or ls1tech since i also have a 95 ta. Now i was ready the N+W+F body swap and some one mentioned that the 95 calipers and brackets can be used since they are the same as impala and monte calipers. And that c5 brakes couldn't be used because of a different bracket. Well on my 95 i'm running c5 brakes.
So here is my why can't i use c5 brakes like my t/a. Don't the 93-97 caliper brackets have the same holes to mount to the spindal as the 4th gen camaro's and t/a's? On my t/a i had to do the following: Get the adapter brackets from umi null
Here
Then these parts:
GM Part # / # needed / Description
12530682 / 1 / Caliper, Guide pin bolts included (standard gray C5)
12530683 / 1 / Caliper, Guide pin bolts included (standard gray C5)
88895128 / 1 / Caliper, Guide pin bolts included (red Z06) OPTIONAL
88895129 / 1 / Caliper, Guide pin bolts included (red Z06) OPTIONAL
10445856 / 1 / Right Rotor (standard factory fitment)
10445857 / 1 / Left Rotor (standard factory fitment)
88925547 / 1 / Right Delco Durastop rotor, lower cost OPTION
88925548 / 1 / Left Delco Durastop rotor, lower cost OPTION
12455799 / 2 / Pad abutment bracket
10333772 / 2 / Front caliper brake hose
12530697 / 4 / Pad abutment guide pin
12530703 / 4 / Guide pin boot
22163795 / 2 / Banjo bolt
10139097 / 4 / Banjo bolt copper washers
CHOICE OF PADS AVAILABLE THROUGH GM DEALERS:
12480154 / 1 / Hawk HP+ front axle pad set (does NOT include anti-rattle springs or pad abutment shims)
88909667 / 1 / Durastop Ceramic front axle pad set (includes springs & shims)
88952008 / 1 / Z06 front axle pad set - RECOMMENDED - (includes springs & shims)
The only thing is you have to use 17's in which i have on the fire.
Nice find and duly noted in my files.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
so is the only thing hindering the n-body aluminum knuckles/hubs the bolt pattern and the ball joint size?
is there a way to install a 5X100 j-body hub into the n-body knuckle? i would think if you did that then all you would have to do is mod the 99 n-body control arms shorter but use the n-body ball joint.
yes? no??
You look so much cuter with something in your mouth.
z yaaaa wrote:so is the only thing hindering the n-body aluminum knuckles/hubs the bolt pattern and the ball joint size?
yes? no??
Here are the specs for the 2000 Malibu LS which has the aluminum knuckle.   Below are the specs for the hub assembly.
 	 A= 4.921 in.; B= 3.937 in.; (C) BOLT SIZE (QTY) M12X1.5 (5); D= 2.244 in.; E= 2.295 in.; F= 1.749 in.; G= 2.894 in.; (H) BOLT CIRCLE DIA= 3.858 in.; (I) BOLT HOLE SIZE (QTY)= .510 in. (3); (J) SPLINE COUNT= 33; (K) FLANGE SHAPE= MODIFIED TRIANGULAR; KI
Here are the specs for the Cavalier hub assembly.
Notice there is no difference in the two?
I'd imagine that all the difference is going to be will be the wheel stud sizing of 5x115 compared to the 5x100 Cavalier size.
So why wouldn't the J-body hub fit the N-body knuckle?
This really has me thinking.   *thinks*
I wish I could get to the junkyard to test this theory out.
If someone has tried this, please let us know.
So in theory we could have the J-body hub assembly mount into the N-body aluminum knuckle with an N-body ball joint along with an N-body tie rod end.
Any takers on this or anyone have more info on this concept?
Misnblu.com
National Bearing:
Part Number: 513017K
This product fits the following vehicles - click on a vehicle to see detailed engine information.
	BUICK 		back to top
	1984 - 1989 SKYHAWK
	1985 - 1987 SOMERSET
	1986 - 1998 SKYLARK
	CADILLAC 		back to top
	1984 - 1988 CIMARRON
	CHEVROLET 		back to top
	1987 - 1996 BERETTA
	1987 - 1996 CORSICA
	1984 - 2005 CAVALIER
	OLDSMOBILE 		back to top
	1992 - 1998 ACHIEVA
	1988 - 1991 CUTLASS CALAIS
	1985 - 1987 CALAIS
	1984 - 1988 FIRENZA
	PONTIAC 		back to top
	1985 - 1998 GRAND AM
	1985 - 1994 SUNBIRD
	1984 J2000
	1995 - 2005 SUNFIRE
Misnblu.com
2000 Grand Am specs use the same hub assembly which would be identical to the Cavalier and Malibu.
So what's the difference?
I'm willing to say that someone hasn't tried to actually take a J-body wheel hub assembly and attached it to a N-body knuckle.    This being the case, we could be on to a nice mod in which all we need are the parts as posted a couple of post up.
Please correct me if I'm wrong.
Thanks.
Misnblu.com
99 grand am specs
hub bearing
Part No: 513137
Description Value
ABS/Non-ABS Y
Bearing Type Ball
Bolt Circle Diameter B 4.52755905511811
Bolt Circle Diameter B 115
Bolt Circle Diameter H 4.56692913385827
Bolt Circle Diameter H 116
Bolt Quantity Size I M12x1.75
Bolt Quantity Size I (3)
Brake Pilot Dia E 2.77952755905512
Brake Pilot Dia E 70.6
Driven - Non Driven D
Flange Diameter A 5.72834645669291
Flange Diameter A 145.5
Flange Offset F 37.1
Flange Offset F 1.46062992125984
Flange Shape J Modified
Flange Shape J Triangle
Gen Type 3
Hub Pilot Dia G 3.5992125984252
Hub Pilot Dia G 91.42
Lug Bolts (Y/N) Y
Pass Y
Roll Form N
Spline Quantity 30
Stud Quantity Size M12x1.5
Stud Quantity Size (5)
Tone Ring / # Teeth -
Tone Ring / Sensor / Encoder S
Tone Ring Dia. -
95-05 j body
j hub
Part No: 513017K
Description Value
ABS/Non-ABS N
Bearing Type Ball
Bolt Circle Diameter B 3.93700787401575
Bolt Circle Diameter B 100
Bolt Circle Diameter H 98
Bolt Circle Diameter H 3.85826771653543
Bolt Quantity Size I 0.51
Bolt Quantity Size I 12.96 (3)
Brake Pilot Dia E 58.325
Brake Pilot Dia E 2.296
Flange Diameter A 4.92125984251969
Flange Diameter A 125
Flange Offset F 44.43
Flange Offset F 1.7492125984252
Gen Type 3
Hub Pilot Dia G 2.89370078740158
Hub Pilot Dia G 73.5
Lug Bolts (Y/N) Y
Pass Y
Roll Form N
Spline Quantity 33
Tone Ring / Sensor / Encoder -
Tone Ring Dia. -
J-body hub will not fit malibu,99 newer grand am, alero, etc-- been there- checked years ago
The thing you don't state in your statistics above are that the Grand Am you got that hub assembly for is for the V6 engine.   This would be normal because the drive shaft would be totally different in the design.
The specs I posted are for the 2.4 liter twin cam engine which would be the same as far as the spindles are concerned.
I've double checked this in several places and all hold this to be true.
I wouldn't want to have a hub that is for a V6 on my Cavy so why post that up?
Any other proof that the hubs for a 2.4 cylinder engine from a 1999+ Malibu or Grand Am won't fit or are interchangeable with the knuckles of the said vehicles?
The only other scenario I can figure out is that the aluminum knuckle was only used on the V6 which to be honest, has never been mentioned on the forums.
More information on this if it's out there, please.
Misnblu.com
I've also taken notice that there are provisions for the hub to have 5x100 studs installed whereas you could remove the studs in the 5x115 pattern.   Or, you could just get the wheel hub assembly for the J-body and not have to worry about it.
This has me really thinking and will do more research once I get some time at the junkyard.    It rained this past weekend so I was not able to do any checking on the Beretta radiators either.
Again, more information would be great whether it's good or bad for the theories we have started here.
Misnblu.com
Part No: 513137
Make Model Position Year App Location
CHEVROLET - FRONT DRIVE Malibu, Fleet Classic (Fleet Vehicle) FRONT WHEEL 2005-2004 Classic
CHEVROLET - FRONT DRIVE Malibu, Fleet Classic (Fleet Vehicle) FRONT WHEEL 2003-1997
OLDSMOBILE - FRONT DRIVE Achieva, Alero, Cutlass Calais, Cutlass Supreme FRONT WHEEL 2004-1999 Alero
PONTIAC - FRONT DRIVE Grand Am FRONT WHEEL 2005-1999
so what you are saying is that GM used a different hub bearing for the 2.4 engine?? instead of using the same hub for all models
where are you getting your info!!
listening
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
This is the part number for the J-body hub and all 2.4 1999+ Malibu's and Grand Ams.  National Bearing:
This is the part number for the N-body 99+ V6 models.  Part No: 513137
Both are National brand.
The V6 will use a different tranny than the 2.4 engine and because of commonality  of the 2.4 engine/ tranny combo in GM's lineup, they use the same hub as noted in the posts above.
This information comes from Advance Auto Parts but I've not checked the AutoZones or O'Reilley's.
So if this IS the case, then it's a simple swap and like ray Gardner stated, gives us the opportunity to continue with out hub assemblies with the 5x100 hubs while upgrading our knuckles to aluminum and our brakes too.
This is why I'm presenting this question to those that have done this swap for more information on what they used and why.
The only thing that would throw all this out the window would be if GM used a beefier knuckle for the V6 model that is being used for the NWF swap.
So far, nobody has disputed the information that I've presented but don't take this as gospel just yet as this almost seems too good to be true.
I really hope it is.
Misnblu.com
 AUTOZONE
     STORE SHOPPING LIST
Send a list to your store ONLINE SHOPPING CART
Shop online today
  Current Vehicle:  1999 Pontiac Grand Am (2.4L SFI DOHC) Add another vehicle  Manage My Vehicles | View Repair Guide
< Home | Shopping Wheel Bearing/Hub Assembly-Front  Valucraft / Wheel Bearing/Hub Assembly-Front
  for a 1999 Pontiac Grand Am
      About this product:
Part Number: V513137
Weight: 7.85 lbs.
Pricing:
   $89.99
Availability:
Store:  Normally stocked at your local store.
Online:  Ships within 2 business days
Shipping Restrictions:
Overnight and two-day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses
autozone 2.4 grand am
OREILLY
Based On This Information
Vehicle:  1999 PONTIAC GRAND AM - 4-146 2.4L DOHC
Replacement Category: Hub Assembly (Bearings & Seals)
Back   Different Search  Sort Results By:   Price   Availability   Manufacturer   Item Type
Description Availability Price
NATIONAL BEARINGS/NATIONAL HUB ASSY - Front Hub Assembly
Item #: 513137
  2 Per Vehicle
  1 year limited warranty (View Details)
  FWD
Online - Available now
Store - Available now
 $98.99
Each
o reilly auto 2.4 grand am hub
all this info is in the nwf swap sticky but:
No the J hub will not fit a N knuckle. and the N hub is dual drilled for 5x 115 and 5x 110
Well after further research with the other car parts companies, I found a glitch in the AdvanceAuto parts menu.
It seems if you just change vehicles after you've already found your hub for say a Cavalier, that same hub will come up with the newer Grand Ams and Malibu's.
Chalk one up for a faulty search engine and I stand corrected.
I knew this to be good to be true and thank everyone for the corrections.
If I thread jacked, sorry for that too.
But I won't be discouraged because the NWF swap is in the plans for the 'blu.
Thanks everyone for the feedback on this.
Misnblu.com
sorry if im way off on this but wat a bout an older grand am with the 5x100 would that mabey work just a thought
ray gardner wrote:sorry if im way off on this but wat a bout an older grand am with the 5x100 would that mabey work just a thought
got a little deeper in the sticky and pretty shure i awnsered my own question  they wont work
so exactly why wont the j-body hub bolt into the n-body knuckle???      im not to familiar with this area of suspension so please forgive me if its something stupid.
and really i see dont see why it wont work to do what you said, misnblu...    just push out the n-body studs on the hub and put in the j-body 5X100 studs. seems to me that it should work....
Edited 1 time(s). Last edited Thursday, December 04, 2008 9:02 PM
z yaaaaaaa the other bolt pattern is 5X110 if i recall correctly.......
watch for flying sparks!!!
^^^ ah. thanks for clearing up the confusion. its something ive always wondered about doing.
and about pushing the n-body studs out and installing the j-body studs in the 5X100 holes? will that work?
boostNbags wrote:z yaaaaaaa the other bolt pattern is 5X110 if i recall correctly.......
because if boostnbags is right the other set (the non 5x115) are really 5x110 not 5X100 so even if you swap the studs to the other set of holes its still diffrent then the js
hmmm....
