So I have been working with Marcus for the past few days on adapting his Current Upper Strut Mounts to work with the Older, More common Easystreet Convulsion bags. I finished drawing up the design today and with the help of my friend CDC milled up a prototype.
My Goal here is to Still utilize the Easystreet Teflon Bearing, But make a much more reliable mount.... WITHOUT sacrificing ride height OR quality. Also NO Modification to the Easystreet bag setup.
This will also fix the apparently common problem shown here
Bandwidth Maxed, Will be back up soon)
Here is the first prototype, We Modified OEM's current Bushing and Added on a new Contact Plate for the bearing.
Heres an album of everything machined and assembled(Except the Pillowball mount plate).
http://hotmodelphotography.com/OEMMount
The Finished Mount should be 1 Single Steel piece, not 2 as pictured.
Original Bushing, Just for comparison:
Easystreet Strut Top, Shows Damage to threads from failed Easystreet mount:
Easystreet's Crappy Design:
Prototype adapter Milled:
Assembly as it stacks onto bag plate over strut:
Test fit on strut w/o Pillowball and Plate(Installs Over Light Silver Piece under Washer):
I am Out of posts until Wednesday, I will answer any questions then!
Chazz wanted me to start an interest list so here ya go guys, throw your names in if your interested.
1.
2.
3.
4.
5.
6.
7.
8.
9
10.
1. Tinkles
2.
3.
4.
5.
6.
7.
8.
9.
10.
I wont have $$ for these until the summer, but the are on my to do list.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
im down for a set!! will make a payment asap. thanks for doing this!!
1. Tinkles
2. Phewes
3.
4.
5.
6.
7.
8.
9.
10.
IM BACK! and obviously! OEM should chime in any time now.
1. Tinkles
2. Phewes
3. Chazz
4.
5.
6.
7.
8.
9.
10.
Cool,cool. Looks like the list is getting bigger. Once I get this proto adapter plate I will see where this list is and go from there. I can still make them if the list does not get to 5-10, just might be that big of a discount.
http://www.overkillengineeringmotorsports.com/
1. Tinkles
2. Phewes
3. Chazz
4. Twisted...depending on price.
5.
6.
7.
8.
9.
10.
I THINK you should get it today OEM, if not today Deff tomorrow. Hopefully soon haha, I rigged up my ES mounts to work for now, but I dont know how long they will last. Hopefully We can get something on before my 6 hour Drive to TN on the 17th
USPS, Same Envelope you sent it to me in. Ill PM you tracking.
Anyone know if this will work with Air Lift fronts? I have Air Lifts but I could have the same trouble in the future as Chazz.
FOR SALE
Air Lift makes the Easystreet kits.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
1. Tinkles
2. Phewes
3. Chazz
5. BaggedOn20s...as long as you don't want my first born child.
6.
7.
8.
9.
10.
FOR SALE
sndsgood wrote:help a slow guy out. is this just a more secure beefy mount instead of the ole thick washer and nut setup? i just noticed last week how my waster are starting to curl up around the bolt on mine.
Basically yes. A bunch of us are having problems with easystreet's washers not holding the strut in the center of the mounting plate. This will fix that problem.
See this thread:
http://www.j-body.org/forums/read.php?f=3&i=140862&t=140862
Edited 1 time(s). Last edited Thursday, April 02, 2009 4:13 PM
Tinkles
2003 Cavalier 1SV
Bagged and Blown
Gah lazy! haha jk....
1. Tinkles
2. Phewes
3. Chazz
6. Wayders
7.
8.
9.
10.
Chazz with the Camera(SpyWiz)]Gah lazy! haha jk....
1. Tinkles
2. Phewes
3. Chazz
6. Wayders
7. FiR3Ma5t3r (Shawn Coleman)
8.
9.
10.
Edited 1 time(s). Last edited Saturday, April 04, 2009 7:10 AM
Now I am not 100% on this, But I think you should be looking at AROUND $180 Shipped. But I am not sure. He will be able to do them in Camber adjustable too I'm sure as the upper plate is the same, which will run AROUND $240 shipped, But I'm not sure if using the camber adjustment will cause the bags to rub on the strut tower(A BIG no-no). So You may just want to stick to the NON adjustable mounts and use the lower adjustment on the easystreet struts.
Mind you, this is just my BEST guess, however I know the Air-Mount's will be made from stainless which may cost more to produce than the coilovers aluminum bracket.
Marcus said he should have the first test pair done this week for me to install and try out, and I'm guessing he should have a final price at this time.
Hope this helps.
was hoping the price was lesser than that but they sure will save my money on replacing bald tires almost too often due to alignment.
also i would love to have them in by this long weeekend. keep us updated how it goes..
