here is what we are running on our new race car...
tokico d-specs
rr spring 200
lr spring 250
rf spring 125
lf spring 150
all springs are 5"x8"
fornt springs have an djustable screw type spacer under it
aluminum control arms, stock on the rf, lf is cut down 3/4 inch
building custom k braces for the front and rear
still debating on what sway bars will work the best on the track
good call on the aluminum control arm on the right front. ive always wanted to see some stock car guys try this. moves your balljoint out a half inch without the officials knowing its not stock for the vehicle (if you paint it black) LMAO.
do you have a z24 rear traling axle? if not, get one. they have a make shift 'sway bar' welded inside it. officials will never know.
id say grab a set of OEM's solid mounts, and if you get the camber ones up front, have fun. wont be able to hide em though...
I'm tired of wasting my time... now I'm breakin' free.
I'd like to see some of this work Bob.
I'm always a fan of custom work.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
where can you get the aluminum control arm? I run a stock car and would like to try that
junkyard, they are from 99 grand ams and aleros only with the fe3 suspension, i got the arms for $40 each
