Lookin for both a k brace and a sub frame brace to run the new seat belts ....
What?
TTR makes subframe braces, but what does that have to do with seat belts?
Edited 1 time(s). Last edited Sunday, February 26, 2012 7:42 PM
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
I wanna run a 5 point racing harness to go with my racing seats I got and get rid of all the oem belts
I wanna run a 5 point racing harness to go with my racing seats I got and get rid of all the oem belts I bought a daily driver and their will he even more time and work going into this car working on getting the last few pieces for the m62 that's goin on my Eco
First, this belongs in interior...
Second, the two items you are asking about have nothing to do with seatbelts. You're asking for a harness bar. The only two manufacturers I know of that had a bolt in option discontinued those.
Third, how do intend to run the harnesses? If you are planning to go straight to the floor after going through the seat holes, it is too steep an angle and can cause more injury than with the stock seatbelts.
Fourth, if you get in an accident on a public roadway and sustain injuries, unless your harnesses are dot approved, don't expect an easy process afterwards. Unapproved or improper safety equipment + insurance companies = oil and water.
Lastly, if this car is being built for show use only, ignore point 3 and 4.
More importantly running a harness without at the very least a rollbar is asking for death should you ever end up in a roll over or have a large vehicle hit your car.
Want hub spacers rear disk brackets or trailing arm bushings? Shoot me a PM.
I want the belts more for look then anything no to be used on a everyday basis but if I were to use them everyday is their any suggestions or anything that I could do to have it fully functional still be safe and not build a full roll bar system...
No you need at the very least a rollbar there is no way around it. even then tho I wouldn't use them on the street.
As for the k brace where to find them and what are the advantages of having them and does anyone have pics of where the aftermarket sway bars go for the rear I am still new to a lot of this but still wanna do a lot of upgrading just not sure what else to do suspension wise to stiffen it up even more
Ttr had a K brace and I sell a sub frame connector. As for your questions on the sway bar one you get one in your hands you'll see how it goes.
Club Teh Jeffie wrote:Ttr had a K brace and I sell a sub frame connector. As for your questions on the sway bar one you get one in your hands you'll see how it goes.
 yea the teh jeffie subbrace works great when he sends the brackets with it hahaha. me need them brackets too jeffie.
Well the plans for power is the m62 kit if that helps on a deciding factor of what I should do with the belts I have a stock pulley goin on and would like to run the heat exchanged I got...as for the suspension so far I am running the ttr sway bar links the addco front sway bar with poly mounts I have the complete Koni yellow set up and have the front upper and rear upper strut bars just trying to get a lot better and stiffer handling out of the car through braces and strengthining of the the rest of the suspension and other thought or input about what u guys think I could do I am still open to thoughts.... Thanks for your guys help so far much appreciated as for the floor brace ( the ones the go in the interior) whatare they generally used for....
Jeffie pm me or let me kno what everything usually runs about price wise for the kbrace..
Lance Detwiler wrote:I want the belts more for look then anything no to be used on a everyday basis but if I were to use them everyday is their any suggestions or anything that I could do to have it fully functional still be safe and not build a full roll bar system...
I plan on running harness in the future with a roll bar, but they will only be used for when i am autocrossing.  On the street i'll use the stock seatbelts.
Error: Sig not found.
Rallye 3 ASM - Schroth Racing Harnesses
Schrotch Racing Rallye 3 are your best choice for a harness without roll/harness bars.  I've called them, and these are what they suggested.  Just make sure you order the proper side(s).
Good Luck.
NCR-SCCA
Hmm thanks racer that helps do u know about what they cost each or by set???
$169 per side at
Soloperformance.com  with free US Shipping.  Order from them unless one of our forum vendors can get these items to you.
NCR-SCCA
Overkill how would u go about getting them and are they any cheaper....
Turbo tech.....  I have bought from u guys before what is the price on the kbrace and color...
Lance Detwiler wrote:Overkill how would u go about getting them and are they any cheaper....
Ill let you know in a bit.
Mark
http://www.overkillengineeringmotorsports.com/
Chelotus Racer wrote:$169 per side at Soloperformance.com  with free US Shipping.  Order from them unless one of our forum vendors can get these items to you.
And with them if you are an scca member you get 10% off, IRRC. If you dont want to put in a harness bar I would suggest going to the rear decklid with some reinforcement added to it. Other car forums have some good write ups for that. IRRC a good one was on an rx7 forum.
Sponsored by:
Kronos Performance
Help me understand why exactly it is bad to run a harness straight thru the seats and down to the seat bolts?  I e seen lots of people do it that way.
GMR has got nothing on this
