Hey guys, I'm getting all my suspension and brakes done within the next two weeks. So far I have in the list...
Suspension:
Tokico HP Blues
Tein S-Tech Springs
Monroe Front Mounts
O.E.M Solid Rear Mounts
Poly Control Arm Bushings
Brakes:
Hawk HPS Pads
Russell Stainless Steel
Power Slotted Rotors
Timken Front Wheel Bearings
Acdelco Rear drums
Acdelco Drums Shoes
Acdelco Wheel Cylinders
Acdelco Inner and Outer Tie rods
Acdelco Lower Ball Joints
New Drum Hardware
What else am I missing guys...I see some members talk about protectors for the suspension and also bump stops..I called the dealer and they said I don't need that? help me out please. Thank you.
Hardware for the rear solid mounts. Unless you get some, I know I didn't,
Dust boots / bumpstops.
Could dish out some cash for new calipers.
An alignment
________________________________________.
Still not low enough for a signature.
thank you for the response. What is the part number for the bumstops. Are the dust boots a must? And for caliper, I really wish I could but im just going to get mine cleaned up/check and painted
Technically, no, you don't need dust boots... but if your OCD about your stuff you might want to.
IDK part numbers... I'm picking up some bumpstops from Ground control.
i would run dust boots, they help protect the strut/shock piston from getting nicked or scratched from rocks and debris which can casue premature wear and or ripping of the valve seals.
control arm bushings, sway bar bushings.
Can i ask why you are doing oem solid rear mounts but stock replacements up front?
Thank you all for responding. Addicted to meth, I do have the pro thane control arm bushing, just forgot to put it in the list though thank you.
Spitfire, thank you for the heads up, where can I gets some cover boots and stop bumps that are good quality and will last.
Start, reason why is because I had the rear from long time ago I bought new from a member here for 60buck brand new,and the front I got them for free from my friend.
Guys, please help me with part numbers for some stop bumps that are good quality and boot dust covers. I highly appreciate your feedback.
